Wrong .ini ...Yaw error
06 Jul 2016 18:58 - 06 Jul 2016 21:23 #51367 by ursus69
Wrong .ini ...Yaw error was created by ursus69
Hi!!
I'm building a diatone tyrant 215, with the F3 Acro 6DF and Orange V620X....and I have a strange problem..
I configured with cleanflight and my devo10 ...and the tyrant no YAW to right...and yaw to left perfectly...
My devo10 works well with my 200QX... and the controller tab in cleanflight seems ok..
I attach the .ini.....but I thinks it's ok..
What could be the problem??
Last edit: 06 Jul 2016 21:23 by ursus69.
06 Jul 2016 20:02 - 06 Jul 2016 20:17 #51369 by ursus69
Replied by ursus69 on topic No right Yaw
I'm doing tests in cleanflight.... and when the quad is disarmed, the yaw works ok..
But when the quad is armed only have left yaw!!
I use the RUDD D/R (channel 10) to arm/disarm...and it's a simple mix....how affect to yaw (channel4)??
I see that the mixer in rudder is wrong....and when I use the rudd d/r blocks the right yaw...
How I would have to set the channel4 (yaw) mixer??
P.D....sorry for my bad english and bad deviation ini :P
Last edit: 06 Jul 2016 20:17 by ursus69.
07 Jul 2016 01:59 #51378 by mwm
Replied by mwm on topic Wrong .ini ...Yaw error
Delete the second mixer in that mix. That's what I'd blocking the yaw with dr.
If you want real dr on the rudder, try using an expo&dr mix instead of a complex mix.
07 Jul 2016 12:46 #51400 by ursus69
Replied by ursus69 on topic Wrong .ini ...Yaw error
Perfect! Thanks mwm!!
Time to create page: 0.037 seconds
