Will simulator hotprops work with Devo 7e
17 Jul 2016 12:34 #51787 by Michael_Hahnel
Will simulator hotprops work with Devo 7e was created by Michael_Hahnel
Hi
Just wondering if anybody tried hotprops with Devo 7e ?
www.hotprops-fpv-race.com/download/
totally new to this but believe that this is a good simulator to learn FPV
17 Jul 2016 16:30 #51793 by HappyHarry
Replied by HappyHarry on topic Will simulator hotprops work with Devo 7e
I hadn't heard of this one yet so thanks for the heads up, and after a quick look through the manual for it I can say yes deviation tx's will work with this sim no problem
18 Jul 2016 06:31 #51812 by Michael_Hahnel
Replied by Michael_Hahnel on topic Will simulator hotprops work with Devo 7e
Great thanks for the info. All I need to figure out now is how to setup the Devo 7e.
=> Nay help with this would be great
Below is a link of Matt who is using this sim and is a great pilot
30 Jul 2016 17:12 #52296 by Michael_Hahnel
Hi ,
Can you help with the setup of the Devi 7e using the supplied USB cable and an iMac PC ?
30 Jul 2016 23:29 #52305 by bazsound
Replied by bazsound on topic Will simulator hotprops work with Devo 7e
i dont think the 7e can be used used as usbhid gaming pad via usb.
you would need to use the dsc output and ither with a USB PPM converter or theres smartproplus which allows you to plug into you soundcards mic input to read the PPM signal ( i tried it on my devo 10 though and it was intermittent and unpredictable)
30 Jul 2016 23:53 #52306 by D_an_W
Replied by D_an_W on topic Will simulator hotprops work with Devo 7e
USBHID works ok here with Heli-X on the Mac
31 Jul 2016 16:46 #52328 by HappyHarry
bazsound the 7e works perfectly well using usbhid bud
01 Aug 2016 02:32 #52353 by Michael_Hahnel
Yes I did get my Devo 7e working with the iMAC and the HotProps simulator
* Just by using the "usbhid" protocal
=> Thanks
12 Oct 2016 00:44 #54839 by raketemensch
Replied by raketemensch on topic Will simulator hotprops work with Devo 7e
Are you guys running Sierra?
I can't get USBHID working on my MBP for the life of me. As soon as a model with USBHID loads in my 7e, using the stock USB cable, my mouse just wants to live in the bottom right-hand corner of the screen, and it doesn't want to leave.
13 Oct 2016 09:34 #54872 by DJDavid33
Replied by DJDavid33 on topic Will simulator hotprops work with Devo 7e
Hello have you configure .ini file for devo 10? Thank you
Time to create page: 1.183 seconds
