Devo-10: 12 Channel Barrier
19 Jul 2016 22:37 #51898 by lasakro
Devo-10: 12 Channel Barrier was created by lasakro
Is there anyway Deviation can create more than 12 channels for the Devo-10 or is it limited by the hardware? I'm using SBUS to a PixHawk and have run out. Now it's time to make hard choices.
20 Jul 2016 07:52 #51910 by Thomas.Heiss
Replied by Thomas.Heiss on topic Devo-10: 12 Channel Barrier
How many channels could you get max on a CC2500 on FrSkyX protocol?
The internal CYRF module probably is max 12CH??
20 Jul 2016 08:45 #51913 by HappyHarry
Replied by HappyHarry on topic Devo-10: 12 Channel Barrier
there's code available on here for 16ch dsm so I don't think it's a devo issue, more a protocol frame length issue
20 Jul 2016 08:55 #51914 by lasakro
Replied by lasakro on topic Devo-10: 12 Channel Barrier
After posting this question I found THIS .
10.6. Protocol: DSMX
The DSMX protocol is used to control many Spektrum™ and JR™, as well as other models using this protocol. While the DSMX protocol can support up to 14 channels, Deviation is currently limited to a maximum of 12.
20 Jul 2016 09:14 #51916 by Thomas.Heiss
20 Jul 2016 10:43 #51919 by Fernandez
Replied by Fernandez on topic Devo-10: 12 Channel Barrier
Frsky X has 16 channels and also Flysky AHHDS 2A, 14channels, so yes there are protocol with more than 12 channels.
I also thought that somehow deviation was limited to 12, so is that true?
20 Jul 2016 14:34 - 20 Jul 2016 14:35 #51926 by HappyHarry
current builds are limited to 12, but that's a programming limitation not a hardware one, if you read the thread linked by thomas you will be able to find the required code changes
Last edit: 20 Jul 2016 14:35 by HappyHarry.
20 Jul 2016 14:41 #51928 by victzh
Replied by victzh on topic Devo-10: 12 Channel Barrier
As far as I can tell it's a matter of one define - you can set as many channels as your MCU can bear (probably Devo 7E is the limiting factor).
See deviation/src/target/devo10/target_defs.h NUM_OUT_CHANNELS. It is set to 12 now, it should be just a matter of changing it.
20 Jul 2016 16:11 #51932 by mwm
Replied by mwm on topic Devo-10: 12 Channel Barrier
There are two other possible issues beyond just changing the #define in deviationTx. First is that there may be a bug in deviationTx that such a change uncovers (well, I'd say it's a bug, but given that it works now, maybe not). Second is that the protocol supports the extra channels in the same format as the earlier ones. Some protocols tweak the formats as you get to higher-numbered protocols.
Which actually brings up a third issue. The protocol code may need to be changed to copy values for the extra channels into the outgoing packets.
If someone is interested in actually testing such, I'd be happy to provide a build for a Tx with a specific protocol tweaked.
20 Jul 2016 17:11 #51933 by lasakro
@mwm,
I'd be happy to test such a build.
20 Jul 2016 23:48 #51939 by hexfet
Replied by hexfet on topic Devo-10: 12 Channel Barrier
mwm wrote: Which actually brings up a third issue. The protocol code may need to be changed to copy values for the extra channels into the outgoing packets.
I think for FrskyX you'd just need to change the value returned by the PROTOCMD_NUMCHAN case. Probably should be 16 anyway, but never checked if values greater than NUM_OUT_CHANNELS would cause problems.
21 Jul 2016 02:46 #51948 by mwm
lasakro wrote: @mwm,
What transmitter and what protocol? I don't have anything an Rx to test with, I'm just offering to build one for someone who can but can't do the build.
24 Jul 2016 05:57 #52071 by lasakro
Sorry about that. I thought we received instant email notifications when we subscribe to a thread here but I guess I can't find where to turn it on.
Devo 10, DSMX please sir. Thanks.
I'll check back more frequently, I promise.
25 Jul 2016 03:50 #52112 by mwm
Ok, I've tried to attach it, but that doesn't always work. If not, I'll do something else.
This is a Devo10 build based on the 5.0 release. If you're running that, you can just install the dfu. If not, use the 5.0 release file system with this. Nightly build file systems might work, but I'd rather not introduce extra variables. Which is also why I used 5.0 release.
I've bumped the overall max channels to 16, because that's where we are heading. However, the DSMX code only had obvious places for 2 extra channels, so you get 14 channels for it. This was done blind, so I had to guess about where they would go, and Spektrum may have taken things in a completely different direction, so don't be surprised if it doesn't work at all.
After making sure your original 12 channels still work, try them both at once. I may have cross-connected them.
And I did learn something: there's more that has to change than just the NUM_OUT_CHANNELS define for the Tx. The datalog stuff has to change a bit as well. PBR set things up so that changing the datalog format breaks the build, so the version number gets updated.
25 Jul 2016 07:57 - 25 Jul 2016 08:01 #52125 by lasakro
Replied by lasakro on topic Devo-10: 12 Channel Barrier- First 14 Ch Test
Great, thanks.
1) I was running 5.0
2) Installed dfu from above.
3) Now in Mixer only channels 1 and 2 configured. 3-12 are all set to none.
4) Reloaded current model file, no change.
5) Loaded different file, no change. Not reading model files.
6) Configured manually in mixer ch's 3 and 4 as Thr & Rud.
7) Configured manually in mixer ch's 5-14 all Simple and Src=Aux4.
Eight) All 14 channels on Devo 10 Mixer Page, as a group, responded as programmed. Didn't check 1 for 1.
9) In Mission Planner ch's 1-8 responded as programmed.
10) Scope on ch's 9-14: 9-11 responded as programmed, 12-14 were dead (Flat line, no PWM).
Let me know when you have another one to try.
Last edit: 25 Jul 2016 08:01 by lasakro.
25 Jul 2016 18:00 #52147 by lasakro
Please ignore everything above about not reading model files and setting their mixers to none. I had made a change adding what I thought would be a comment line [comment] under the [channelXX] line and that didn't go as anticipated. I'm going to try [channel10_camera_select] instead. Doesn't seem to like spaces i that field.
14 Mar 2018 12:29 #68056 by hexfet
Post on another thread prompted me to revisit this for FrskyX. Test builds here (19a6cca) .
I haven't updated the datalog code yet so please don't use that feature. Tested with t8sg and XSR receiver SBUS output. All 16 channels worked fine. Channel monitor screen worked as expected. Haven't tested other features.
14 Mar 2018 16:09 #68062 by Hined1
thanks for the link hexfet and that's for the details! i really appreciate all the help. i'm new and i might be having questions, do you mind if i would ask you them? thanks!
15 Mar 2018 00:08 #68067 by hexfet
This site is the place to ask questions. Someone generally answers :) Start a new topic if you're changing subject.
Test builds are updated (3880781). Updated the datalog version, and the conversion utility to support 16 channels. Tested the datalog with 16 channels. Recording and conversion both worked fine.
15 Mar 2018 01:53 #68069 by hexfet
Test builds are updated (3026970). Protocol Flysky AFHDS protocol max channel limit increased to 14. I don't have a way to test this change.
Time to create page: 0.470 seconds
