Devo 12 Blue, Charging LED won't go out....
07 Aug 2016 01:44 - 07 Aug 2016 05:38 #52520 by John-Boy
I have Devo 12 with V4.1 software. I just charged it and now the Blue LED stays on after the radio is turned off.
I removed the battery and reinstalled. The LED comes on the second I install the battery. The radio will power up and work but the LED will not go out.
Tried a 2nd battery and it does the same.
So, the blue is the charge indicator. Everything is unpluged but still lights...
Maybe it will go out after the lipo voltage lowers?
Any ideas would be helpful. Thanks in advance...
John L.
Last edit: 07 Aug 2016 05:38 by John-Boy.
07 Aug 2016 03:53 - 07 Aug 2016 03:56 #52522 by -=Hubi-Dirk=-
Replied by -=Hubi-Dirk=- on topic Devo 12 Blue LED
John-Boy wrote: Hi,
1. So, the blue is the charge indicator.
2. Everything is unpluged but still lights...
3. Maybe it will go out after the lipo voltage lowers?
John L.
1. No, it´s the green LED. The blue will only turn on, when USB or Charger (Power) is connected.
2. Strange, never had this on mine. Whitout battery, the Blue will turn on when USB/Charger is plug in?
3. Don´t know, give it a try.
Last edit: 07 Aug 2016 03:56 by -=Hubi-Dirk=-.
07 Aug 2016 04:09 #52523 by John-Boy
Replied by John-Boy on topic Devo 12 Blue LED
If the radio has power from the battery or a charger (plug or usb) the blue led is on.
Blue led goes out when radio is on.
I just noticed that my clock battery is dead....
08 Aug 2016 01:01 #52563 by John-Boy
Replied by John-Boy on topic Devo 12 Blue, Charging LED won't go out....
Installing a new clock battery did not help...
I was hoping it was a 'clock battery failure' indicator.
22 Oct 2016 13:37 #55273 by docthebiker
Replied by docthebiker on topic Devo 12 Blue, Charging LED won't go out....
Nope the only indication that you're clock battery is failing is you have to keep resetting the time/date. Even not having a 1220 fitted will have no impact on your normal clock function, such as the timer running, but the clock will reset to default (jan 1st 2011 on mine) after every power down.
Time to create page: 0.105 seconds
