WK-DEVO-S-MOD RF Module
- RoGuE_StreaK
15 Aug 2016 10:10 #52768
by RoGuE_StreaK
Replied by RoGuE_StreaK on topic WK-DEVO-S-MOD RF Module
6dbi is probably too high a gain to use, dipole antennas have a "doughnut" shaped radiation pattern when looked at end-on, the higher the gain the narrower/thinner the doughnut becomes, it reaches further out but inversely makes it harder to keep your vehicle within the band of radiation, meaning you can easily lose signal if the antenna isn't perfectly perpendicular to your craft.
2 to 3dbi is usually a good blend of extended range with minimised... dougnutification?
The monopoles used in the 7E and 6S don't have gain, and essentially become a "ball" of radiation, good for keeping control no matter where your craft is as long as it's within that smaller sphere. Turning the sphere into a doughnut gets you further potential range but has side-effects of potentially "falling into the hole" and losing signal if you aren't oriented right.
- aMax
15 Aug 2016 10:53 #52769
by aMax
Replied by aMax on topic WK-DEVO-S-MOD RF Module
These antennas from BG seem not to have a 6di gain on the 2.4 gig band., maybe on 5,8 only.
I was testing these against normal 2dBi ones on my router connected a wireless device runing "inSSIDer".
The signal was weaker......
Some infos for those who are interested in how the radiation and pattern work. Mainly for FPV but .....
- 92zb
15 Aug 2016 11:31 #52771
by 92zb
Replied by 92zb on topic WK-DEVO-S-MOD RF Module
I am even more confused now. Previously my 7e was range moded with conductive ink. With the old module I was using this antenna (see Photo) It was successful with the small drones. But when I started flying model aeroplane with this TX, I was constantly losing contact with the model, within range the motor would cut and no control over the model and then after few seconds contact back and normal. It was not happening once but during the whole duration of flight. Mind you on the ground range test was excellent. I thought might be the conductive ink was not applied properly or it was wearing out. That is why I change the module.
So the conclusion is that I should use this
Antenna 433MHz RP-SMA 2dBi for 3DR Radios @ www.banggood.com/Antenna-433MHz-RP-SMA-2...Radios-p-918634.html
in combination with
Universal 2.4G Receiver Antenna Compatible Futaba JR WFLY @ www.banggood.com/Universal-2_4G-Receiver...-WFLY-p-1005363.html
As now I am totaly confused and I need solid advice,
Thanks again.
in combination with
Thanks again.
- aMax
15 Aug 2016 12:19 - 15 Aug 2016 20:04 #52774
by aMax
Well, what you find in your 7e/6 is also a dipole antenna. but the disadvantage is the fixed direction and mostly
all pilots are pointing straight at the model. At this direction you will have the least range. Simple turning the
radio to a 90 degree angle ( up, down,left,right)
( "flying over the shoulder") to the model and you will gain the most range of it. By using a swivel antenna
this can be preselected.
I am flying with a quality Frsky 2dBi antenna and they work great. There is even a 5dBi V8 antenna.
www.banggood.com/Wholesale-FrSky-2_4G-V8...Antenna-p-68714.html
Recently lost my video but not the rc signal at some height ( antenna orientation) and recovert 800m
away at a lower flight level.
....7e/cc2500
....7e/cc2500
Last edit: 15 Aug 2016 20:04 by aMax. Reason: typo
- 92zb
15 Aug 2016 14:58 #52781
by 92zb
I did a Range Test and at 100uW it worked up to 30 meters and @150mW it was more then 150 meters, could not go beyond because of the boundry wall.
But the stock model (7e range moded) also gave me the same distance. but it was flaky in flight. Well I think I will to test it by realy flying a model with it and see what happens.
- RoGuE_StreaK
15 Aug 2016 21:34 #52787
by RoGuE_StreaK
Sounds more like a receiver brownout, the servos etc sucking too much juice for the BEC, and/or your battery voltage sagging under load. I've had it happen numerous times before I started using beefier separate BECs.
- RoGuE_StreaK
16 Aug 2016 05:53 - 16 Aug 2016 05:54 #52796
by RoGuE_StreaK
Not too sure what you are intending to do with the receiver antenna? Perhaps others are saying to use that as a monopole replacement?
Here's the combo I'm using on my 6S:
- pigtail to get from the module to the case
- 3dbi 2.4GHz antenna
Last edit: 16 Aug 2016 05:54 by RoGuE_StreaK.
- 92zb
16 Aug 2016 08:53 #52798
by 92zb
At first I and my mates thought the same. But then we flew the model with my mate's DX6i and there was no problem
RoGuE_StreaK wrote: Sounds more like a receiver brownout, the servos etc sucking too much juice for the BEC, and/or your battery voltage sagging under load. I've had it happen numerous times before I started using beefier separate BECs.
- 92zb
16 Aug 2016 15:23 #52816
by 92zb
Well today I flew with this Module in Devo 7e TX successfuly no problem. I am using the following Antenna combinatuion :-
Dual Band 2.4/5.8Ghz 6dBi RP-SMA Directional Wireless Wifi Antenna
10cm PCI U.FL / IPX to RP-SMA Female Jack Pigtail Cable
I have placed an order for 3dBi Antenna, and I will try that as well when I receive it in about 2 weeks time.
- pierrotm7777
07 Sep 2018 08:12 #70699
by pierrotm7777
Replied by pierrotm7777 on topic WK-DEVO-S-MOD RF Module
I am new on this forum
I should like to know if the WK-DEVO-S-MOD replace only the CYRF6936 or also add cc2500,A7105 and NRF24L01.
Thanks for your help.
07 Sep 2018 08:23 #70700
Replied by vlad_vy on topic WK-DEVO-S-MOD RF Module
It is stock Devo module and replace only the CYRF6936.
For Devo 4in1 module you need:
www.banggood.com/CC2500-NRF24L01-A7105-C...07.html?rmmds=search
- pierrotm7777
07 Sep 2018 08:38 #70702
by pierrotm7777
Thanks for this very quick answer
It's exactly the module that i look for.
Can you say me if this module is full 5v compatible or accept only 3,3v for MOSI, MISO, SCK and CS/SS ?
vlad_vy wrote: It is stock Devo module and replace only the CYRF6936.
07 Sep 2018 08:53 - 07 Sep 2018 08:54 #70703
It has own LDO regulator 5V to 3.3V (4.5V-8V Input) and powered by 5V. All signal lines work with 3.3V
Last edit: 07 Sep 2018 08:54 by vlad_vy.
- pierrotm7777
07 Sep 2018 09:01 #70705
by pierrotm7777
Thanks you for your help.
vlad_vy wrote: It has own LDO regulator 5V to 3.3V (4.5V-8V Input) and powered by 5V. All signal lines work with 3.3V
- pierrotm7777
07 Sep 2018 09:18 #70707
by pierrotm7777
Sorry, another question.
I want to use this module into our OpenAVRc project.
I see that module has a RESET pin. It's possible to stay this pin not connected ?
07 Sep 2018 10:58 #70714
Without problems. If you need reset, you can use CYRF6936 software reset.
- pierrotm7777
07 Sep 2018 12:26 #70718
by pierrotm7777
Thanks you for all these infos.
vlad_vy wrote: Without problems. If you need reset, you can use CYRF6936 software reset.
Time to create page: 0.378 seconds
- WK-DEVO-S-MOD RF Module
