Turing off the battery voltage monitor
19 Aug 2016 08:37 #52892 by defunced
Turing off the battery voltage monitor was created by defunced
Hey,
I'm busy resurrecting a Devo10 after the previous owner fried the uC. To cut a long story short, electronically its working; USB mode, DffuSe, binds and sends etc, however the top right corner voltage monitor reads: -.--V , I'm getting intermittent "battery too low to write flash" messages and the menu system is largely unresponsive. I'm pretty sure the supply voltage(s) are ok, however the voltage monitor circuit could easily have been damaged.
Is there a way to turn off the battery voltage monitoring function completely ? It would make debugging easier if the firmware could be told to assume the power is good.
Yes there are lots of things that could be causing these problems, the voltage monitor is my currently my best guess.
Time to create page: 0.093 seconds
