DEVO10 button issue and repair !
19 Aug 2016 22:59 - 02 Oct 2016 05:56 #52917 by sfersystem
DEVO10 button issue and repair ! was created by sfersystem
I've a problem on my DEVO10. the "DN" down button work not like the other, sometimes works well, sometimes not. It arrives that with 1 press, the selection jump one line.
can someone help me ?
If it's hardware issue, what sort of switch is it and where can i buy it ?
Thank you
Last edit: 02 Oct 2016 05:56 by sfersystem.
20 Aug 2016 09:24 #52926 by Thomas.Heiss
Replied by Thomas.Heiss on topic DEVO10 button or firmware issue !
What exact firmware version are you on so others might be able to replicate?
20 Aug 2016 09:31 #52927 by sfersystem
Replied by sfersystem on topic DEVO10 button or firmware issue !
I'm running under nightly build : deviation-devo10-v5.0.0-dd199b1
Thank you
21 Aug 2016 09:18 #52964 by sfersystem
In some menus, this button does not work nearly :(
21 Aug 2016 09:36 #52966 by C0ckpitvue 777
Replied by C0ckpitvue 777 on topic DEVO10 button or firmware issue !
I have the same issues with mine,I believe there are a lot of bugs with 5.0 and devo 10 including range issues with some protocols.Before the update I had great range with the 2x2 protocol now it has diminished dramatically.The gurus are the best at ironing out the kinks as long as they are aware of the problem.5.0 is still relatively new and I believe all this will eventually run smooth.
21 Aug 2016 09:51 #52968 by sfersystem
I'm agree with you, i've bought an FRSKY XSR and have dropouts, i've bougth an D4R-II and i have range issue with it. It's maybe the RSSI signal that not efficient but at 300m i'm under 45db, My DEVO beep .. hope all these things will be resolved soon.
" I know many people do a great job and work hard to improve this, and I thank them. "
22 Aug 2016 23:44 - 22 Aug 2016 23:46 #53021 by HappyHarry
Replied by HappyHarry on topic DEVO10 button or firmware issue !
there was a huge gui rewrite (to enable the firmware to work with the at9 which has less input buttons) which caused most of these double bounce button press issues, and a lot of them were already fixed, but obviously there are a few more lurking about. but until the bugtracker is back up and the devs have some free time to look into them there isn't much can be done, unless that is you know C, and can fix the code and submit a pull request, which is beyond my skill levels for sure
Last edit: 22 Aug 2016 23:46 by HappyHarry.
23 Aug 2016 05:03 - 23 Aug 2016 05:19 #53027 by sfersystem
So i'm an isolated case, but i can think that probably come from the firmware.
it is really very annoying
If i post a datalog, can you confirm that ?
Because if i need to replace the button, i can do it instead waiting and finally realize that is an hardware problem.
Thank you HappyHarry.
Last edit: 23 Aug 2016 05:19 by sfersystem.
23 Aug 2016 14:17 #53034 by Thomas.Heiss
So, why do you run the 5.0-nightly-build dd199b1 if you are not a developer yourself?
If you go back to release 5.0 there won't be IMHO the AT9 GUI rewrites in, so not these bugs?!?
Thomas
23 Aug 2016 15:23 #53040 by sfersystem
Thomas.Heiss wrote: So, why do you run the 5.0-nightly-build dd199b1 if you are not a developer yourself?
You are right, but i for binding my XSR i have to install the nighlty !
Thomas.Heiss wrote: If you go back to release 5.0 there won't be IMHO the AT9 GUI rewrites in, so not these bugs?!?
Thomas
Before, with the standard "stable" V5.0 I already had this problem.
So it's maybe a hardware problem !
24 Aug 2016 08:14 #53067 by Thomas.Heiss
XSR = FrSkyX?
Oh, it is not included yet in 5.0 or any sub 5.0.x and still under on-going protocol development (aka trunk/default/master)?
Didn't the developers have plans to backport multi-protocols to one "stable release" builds, 5.0 in your case, too?
I remember I read that once...
It looks to me somehow weird that you have to switch to a true-developer non-100% testing nightly-build release including GUI rewrites just to use some of the later protocols.
Sorry I do not use 5.0 yet.
I can assure you that this release devo10-v4.0.1-fcd0669, I am using myself (well tested on DSMx + telemetry) works 100%.
Would be enough for your testing.
If your problem is gone with fcd0669, then the GUI bug is in release 5.0 + nightly-builds.
If not, it is your hardware button.
Thomas
25 Aug 2016 02:46 #53082 by mwm
Replied by mwm on topic DEVO10 button or firmware issue !
Yup, XSR is FrSkyX. Some of the X series receivers will also do FrSky (aka FrSky D), but I don't think the XSR is one of them.
And yeah, we're supposed to have interim releases with bug fixes and new protocols. So far, only two protocols have been added to the nightly build, FrSkyX and MT99XX. Neither have been added to the manual yet, so they aren't ready for a release. Further, the FrSkyX changes include changes to the FrSky protocol telemetry (they use the same data format), and seem to be causing issues with it. Given the popularity of FrSky - even with the limited telemetry it has in 5.0.0 - breaking it in a release really isn't acceptable. So we don't have any new protocols ready for a point release yet.
FWIW, I haven't had any issues with the buttons on my 10 on 5.0.0. It wouldn't surprise me if the GUI rewrite broke things. I'd say test with 5.0.0 or the release Thomas suggested, and if you don't see the problem there open an issue on the bug tracker when it starts working again.
25 Aug 2016 06:12 #53087 by sfersystem
Ok, mwm, i've just done the clean downgrade to standard release. I erase all files after backup and put the files in the .zip
I have the multimodule with only CC2500, so i modify the hardware.ini
www.banggood.com/CC2500-PA-LNA-Romote-Wi...F24L01-p-922595.html
i'll try and tell if it's the same.
25 Aug 2016 10:43 #53090 by Thomas.Heiss
Thomas
Hmm, didn't you say you already tested normal V5.0 release?
But I suggest to redo testing and then jump to my nightly-build version if the problem persists.
What deletion are you talking about?
For Devo10 there is just the DFU - no protocol files.
The bug for sure is not in the model.ini, template.ini or hardware.ini.
How could it be in tx.ini? You do not have to calibrate buttons?!?
25 Aug 2016 20:53 - 25 Aug 2016 20:53 #53102 by sfersystem
Thomas.Heiss wrote: Hmm, didn't you say you already tested normal V5.0 release?
Yes (see the video below)
Thomas.Heiss wrote: But I suggest to redo testing and then jump to my nightly-build version if the problem persists.
Where to find it ?
Thomas.Heiss wrote: What deletion are you talking about?
All the file under my DEVO folder, and replace with the clean ones
Thomas.Heiss wrote: The bug for sure is not in the model.ini, template.ini or hardware.ini.
Thank you for help
Last edit: 25 Aug 2016 20:53 by sfersystem.
26 Aug 2016 09:54 - 26 Aug 2016 09:58 #53116 by Thomas.Heiss
Last edit: 26 Aug 2016 09:58 by Thomas.Heiss.
27 Aug 2016 02:51 #53128 by Topher
Replied by Topher on topic DEVO10 button or firmware issue !
I had a similar issue with my devo 10. I solved it by opening up the button and cleaning it. You need to open the transmitter, unscrew that circuit board, then you can pop the sheet metal off the button and clean it. Reassemble and give it a try. It worked for me.
-Topher
27 Aug 2016 07:11 - 15 Jul 2017 22:05 #53133 by sfersystem
Thanks guy,
Since I have already changed several times firmware without success program, I opened the DEVO and cleaned the button
It seems to work for now, i wait a while to confirm
Last edit: 15 Jul 2017 22:05 by sfersystem.
01 Oct 2016 22:07 #54484 by Thomas.Heiss
Now I have the same thing with the left (EXT) side button "down" on the Devo10 :-)
A little bit of rain is hurting it, isn't it?
The board is labeled Walkera WK-2410-EXT 2009.06.23.
02 Oct 2016 05:59 #54495 by sfersystem
Maybe the rain could hurt the TX, but mine never saw a drop of water.
i think the contactor are in fault
Time to create page: 0.153 seconds
