Devo 10 3 in 1 module issues
- Podflyer
20 Aug 2016 10:39 #52929
by Podflyer
Devo 10 3 in 1 module issues was created by Podflyer
A big thank you for all the help I've had to get this far. So I still can't get my moded devo 10 working I have installed this module
www.banggood.com/CC2500-NRF24L01-A7105-M...itter-p-1046304.html
I followed the installation guide from there. I have a installed deviation 5.0 and edited my hardware.ini file with notepad++ my file looks like this:
enable-cyrf6936 = B12
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
enable-nrf24l01 = B7
has_pa-nrf24l01 = 1
the Tx starts up fine with no missing module errors. When I try to bind a model I just get a re-init option no bind option and no choice options such as selecting x600 for the mjx protocols. I feel like I'm almost there but can't work out what I've done wrong. I think my module installation was good and I inspected every soldered joint with a magnifying glass. More help please guys!
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
has_pa-nrf24l01 = 1
- D_an_W
20 Aug 2016 12:27 - 20 Aug 2016 12:30 #52930
by D_an_W
Replied by D_an_W on topic Devo 10 3 in 1 module issues
Some models show Re-Init and not Bind, I think thats just a naming thing.
I just tried mine and when I pressed enter on MJXq I get a "pop up" that gives you Format options with four choices (X600 being one of them).
When you scroll through the different protocols do any of them have a * before the name?
I am not sure about this but do you need to enable cyrf6936?
; enable-cyrf6936 = B12*** Walkera Devo 10 * 4-in-1 Module * Deviation v5 *** *** Walkera Devo 7E * A7105 Module * 2x 3 Way Switches * Power Mod * Deviation v5 ***
Last edit: 20 Aug 2016 12:30 by D_an_W.
- Podflyer
20 Aug 2016 12:53 #52931
by Podflyer
Replied by Podflyer on topic Devo 10 3 in 1 module issues
Yep I get a * in front of the mix protocols but no way to choose which version. On my devo 7e I would press ent then choose which model I wanted. This doesn't seem to happen with my devo 10 at the moment.
- D_an_W
20 Aug 2016 13:01 #52932
by D_an_W
A * in front of a protocol means it is not supported (Or configured correctly I guess). With the 4-in-1 I have I don't have a * in front of any protocol, I am not sure what the 3-in-1 supports.
Have you tried your settings in the EMU to see if everything is configured ok?
- Podflyer
20 Aug 2016 13:21 - 20 Aug 2016 13:22 #52933
by Podflyer
I have a * in front of all the protocols I want use v202,mjx, Syma etc. Emu?
Last edit: 20 Aug 2016 13:22 by Podflyer.
- D_an_W
20 Aug 2016 14:20 - 20 Aug 2016 14:20 #52934
by D_an_W
There is an
Emulator
version of each Deviation release that allows you to run the software on a Windows PC which comes in very handy when testing etc.
Last edit: 20 Aug 2016 14:20 by D_an_W.
- Podflyer
20 Aug 2016 16:34 #52939
by Podflyer
I've just open it up an checked every joint and it's wired up right I've also done continuity testing through each wired connection and it's all good. I'm really stuck now. Any one else can help please chip in.
- HappyHarry
20 Aug 2016 19:15 #52941
by HappyHarry
Replied by HappyHarry on topic Devo 10 3 in 1 module issues
if there are asterix '*' in front of protocols then your hardware.ini changes are not done properly
- D_an_W
20 Aug 2016 19:16 #52942
by D_an_W
Now the big guns are here to help
- Podflyer
20 Aug 2016 20:01 #52943
by Podflyer
Awesome... any tips?
HappyHarry wrote: if there are asterix '*' in front of protocols then your hardware.ini changes are not done properly
- Podflyer
20 Aug 2016 20:02 #52944
by Podflyer
you have helped a lot and I'm really grateful looking forward to getting back in the air...
- Podflyer
20 Aug 2016 20:11 #52945
by Podflyer
this is my file
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
has_pa-nrf24l01 = 1
this is my file
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
has_pa-nrf24l01 = 1
- HappyHarry
20 Aug 2016 21:17 - 20 Aug 2016 21:18 #52946
by HappyHarry
you need to comment out the first cyrf line, that doesn't need changed with the 3in1 (or 4in1 to be fair) and make sure to use something like notepad++ if on windows to edit the file, as windows notepad doesn't work propely. also keep in mind 5.0 uses hardware.ini and not tx.ini to store these changes
dan I wish lol
;enable-cyrf6936 = B12
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
has_pa-nrf24l01 = 1dan I wish lol
Last edit: 20 Aug 2016 21:18 by HappyHarry.
- Podflyer
20 Aug 2016 23:15 #52951
by Podflyer
So my file is as below which has been edited and saved in notepad++ all solder joints have been checked and continuity testing done over all wires. still getting a * in front of the different protocols. Could it be a faulty module?
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
enable-nrf24101 = B7
has_pa-nrf24101 = 1
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
has_pa-nrf24101 = 1
- D_an_W
21 Aug 2016 05:09 #52954
by D_an_W
It's possible it is faulty I guess.
Do you have the [module] line in the file also and is the file in the root folder of the Devo 10?
Perhaps this is the minimum you need in Hardware.ini for it to work.
Did you test your configuration in the Emulator yet? If not, zip up your entire Devo 10 folder structure and send me a link to it, I will try it in the Emulator.
extra-buttons=trim-all
[modules]
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
has_pa-nrf24l01 = 1Did you test your configuration in the Emulator yet? If not, zip up your entire Devo 10 folder structure and send me a link to it, I will try it in the Emulator.
- Podflyer
21 Aug 2016 08:37 #52960
by Podflyer
has any one else installed this particular module
to a devo 10 and got it working if so could you please send me your hardware.ini file
- Podflyer
21 Aug 2016 11:50 #52973
by Podflyer
Again if some one could send me a harware .ini file that would be great. Also what encoding should i be using in notepad++ it's currently set to UTF-8
- D_an_W
21 Aug 2016 12:17 #52974
by D_an_W
I just use WordPad in Windows and it works fine. As I mentioned before, did you try using your configuration in the Emulator yet? If you get the * before the protocol name then it must be a config issue, if not then could be a hardware problem.
If you can zip up your entire Devo 10 drive (When connected to the PC in USB mode) as it is now I don't mind testing it at all here.
Also, what version of Deviation 5 are you running, the standard release or a nightly build?
- Podflyer
21 Aug 2016 12:48 #52975
by Podflyer
tried the emulator but could not work out how to use it. File below. Many thanks
- D_an_W
21 Aug 2016 13:10 #52976
by D_an_W
I just took a look at your included Hardware.ini and you have two modules using A13 and two using A14 (See below) also you have the multimod enabled which you don't have, right?
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
enable-nrf24l01 = A14
has_pa-nrf24l01 = 1
enable-multimod = A13*** Walkera Devo 10 * 4-in-1 Module * Deviation v5 *** *** Walkera Devo 7E * A7105 Module * 2x 3 Way Switches * Power Mod * Deviation v5 ***
Time to create page: 0.711 seconds
- Devo 10 3 in 1 module issues
