Calibrate Tx voltage
20 Aug 2016 14:59 #52936 by steadfast4life
Calibrate Tx voltage was created by steadfast4life
I saw an old thread dealing with this issue but no resolution. My devo 10 shows .8 mah lower than the actual value in my life battery. Are their any updates for this problem?
20 Aug 2016 21:26 #52948 by HappyHarry
Replied by HappyHarry on topic Calibrate Tx voltage
as far as i remember there's no way to make this work for every voltage level due to the way it's measured/calculated, just for instance it may be accurate at 12v and again at 9v but in-between it can be off as much as 0.1v. it's never going to be bang on throughout the full voltage range
21 Aug 2016 09:59 #52970 by Fernandez
Replied by Fernandez on topic Calibrate Tx voltage
Normally there is a multiplier and an offset, somewhere in the software.I can,t remember but indeed I think it was once idea instead of having fixed value, to have it in hardware.ini
23 Aug 2016 03:27 #53022 by steadfast4life
Replied by steadfast4life on topic Calibrate Tx voltage
That would be a great idea!
Time to create page: 0.403 seconds
