devo 7e fmod
- andyroberts176
23 Aug 2016 20:38 #53049
by andyroberts176
devo 7e fmod was created by andyroberts176
Newbie question
I have a 7e with deviation 5.0
and cant seem to get the fmod switch assigned to 3 or 6 axis gyro
somebody help it's driving me batty
cheers Andy
cheers Andy
- rjmcewen63
- I know how to fly, I'm learning not to crash...
11 Sep 2016 03:13 #53778
by rjmcewen63
_
/_/ _ _
/ \/_/_\_\
Replied by rjmcewen63 on topic devo 7e fmod
Heres my Master CP model file. The gyro is controlled thru channel 7. My fmod switch changes it from fmod0 - 50 (gyro 75%) and fmod1 - 0 (gyro 50%). There are some other features you might be interested in. The hold switch engages a "sticky" hold. You must return the throttle channel to minimum before the throttle re-engages. Fmod also changes your pitch and throttle curves for 6d flight. I hope this helps. As always, use this file at your own risk. Always test before flying! Good luck, bro!
_
/_/ _ _
/ \/_/_\_\
Time to create page: 0.129 seconds
- devo 7e fmod
