Mixing 2 swashplateS
29 Aug 2016 13:48 #53236 by Block137
Mixing 2 swashplateS was created by Block137
Hi
I'm almost done building my synchropter! :woohoo:
Now I'm trying get all 6 servos working correctly without any flight controller....yet. (Any controller suggestion will be appreciated)
FYI this thing works similar to Chinook -having 2 swashplates, 1 for each rotor.
The problem is rudder control which is done by lowering one swash and raising the other.
I just can't find a way to mix that.
Assigning Cyclic1/2/3 to a VirtX and use VirtX as source doesn't work.
However using Cyclic1/2/3 assigned to regular channels as source worked but that wasted 3 full channels and frames.
DEVO 12S
V5.0.0
01 Sep 2016 10:43 #53361 by Block137
Replied by Block137 on topic Mixing 2 swashplateS
Maybe my question sounds too hard
The real question is:
I set Virt4 as Cyclic1 mixer type (Simple/Expo/Complex/cyclic1 etc)
and then use Virt4 as Src on Ch1. This doesn't work. Ch1 acts like there is no input.
Using Real channel instead of Virt does work but I will run out of channel this way.
Is this normal?
How to get around this problem?
Time to create page: 0.031 seconds
