wireless trainer through cppm receiver
11 Sep 2016 17:11 - 11 Sep 2016 17:12 #53792 by d3relict
wireless trainer through cppm receiver was created by d3relict
dear all,
i'm planning to connect an OrangeRx R920X receiver to the trainer jack on the devo 10, in hope to get wireless trainer (ppm in mixing is already done, we just want to lose the cable).
have anyone done anything like this? is the cppm signal coming from the r920x compatible with the ppm in in devo? any help is welcome :)
Last edit: 11 Sep 2016 17:12 by d3relict.
11 Sep 2016 21:31 #53798 by Cereal_Killer
Replied by Cereal_Killer on topic wireless trainer through cppm receiver
I've done this numerous times. I have made lots of posts here as well as rcgroups as well as my rcgroups blog (same name as here).
What specifics did you need to know?
12 Sep 2016 03:57 #53807 by d3relict
Replied by d3relict on topic wireless trainer through cppm receiver
can you link me to your posts about the matter?
i just wanted to know if this will work, because i was unsure about the differences between ppm and cppm, or if we can get the proper voltage for the receiver from inside the devo10, without using an additional lipo.
12 Sep 2016 12:27 - 12 Sep 2016 12:30 #53811 by Cereal_Killer
Here's the blog post I made on the subject.
www.rcgroups.com/forums/showthread.php?t=2613943
I didn't necessarily male a how to guide or anything.
Note cppm is no different than PPM, the C is just redundant... it stands for "combined" however it doesn't need to be there cause if it weren't multiple channels together it wouldn't be PPM at all (it'd be pWm).
Your voltage concerns are warranted, not sure the orc will accept 5v without range issues.
Note I really suggest you not waste that good of an rx on this job. I use OrangeRx r615x's and Redcon cm-621 (which arnt ppm receivers however $4.99 Redcon rx + $2.19 arduino = ppm receiver for $7).
Last edit: 12 Sep 2016 12:30 by Cereal_Killer.
12 Sep 2016 12:41 #53813 by Cereal_Killer
Ppm Rx built from Redcon cm-621 + arduino.
File Attachment:
File Attachment:
File Attachment:
File Attachment:
12 Sep 2016 16:57 #53818 by d3relict
thanks!
"Your voltage concerns are warranted, not sure the orc will accept 5v without range issues."
is 5v too low?
we can always put in some dc/dc converter to the 3S lipo if there is no suitable voltage for the rx. :)
16 Sep 2016 10:55 #53910 by FrankV
Replied by FrankV on topic wireless trainer through cppm receiver
Hi, I use the orange 6ch receiver with ppm out on my devo10 without any real mods. Just made a dedicated cable to connect it to ppm-in on the Devo10.
Just connect the ppm output to the ppm-in port on your devo.
I dont need more then 6 channels, for a trainer mostly the sticks will be sufficient (4ch) and have still 2 channels left.
I use a 1S 150mAh lipo to supply voltage to the receiver - no issues so far. The range between trainer and trainee is short normally :)
17 Sep 2016 05:10 #53940 by d3relict
we just made the mod yesterday, it works fine :) my friend made a voltage regulator, so the rx can get power from the devos lipo (8v, but the rx can handle 3.7 - 9.6 according to the manual)
Time to create page: 0.217 seconds
