kindly help NRF24L01+
- kaligola
18 Sep 2016 10:12 - 18 Sep 2016 10:13 #54001
by kaligola
kindly help NRF24L01+ was created by kaligola
ive seen this module , stated arduino compatible,
would like to get one to add to stock module in devo 7e with yet A7105 module
is it compatible?
www.ebay.it/itm/Modulo-wireless-2-4Ghz-N...6:g:YNoAAOSwxN5WVxl5
is it compatible?
Last edit: 18 Sep 2016 10:13 by kaligola. Reason: type mismatch
- RoGuE_StreaK
19 Sep 2016 01:15 #54019
by RoGuE_StreaK
Replied by RoGuE_StreaK on topic kindly help NRF24L01+
AFAIK it should work, but with very limited range, eg. 30m at an extremely rough guess?
But for a couple of bucks more you can get one with the power amplifier etc for much longer range; just make sure you figure out how you are going to physically mount it before you commit to buying!
with hard-wired antenna mount
more flexible (install), but more expensive
- kaligola
19 Sep 2016 08:21 - 19 Sep 2016 08:22 #54028
by kaligola
Replied by kaligola on topic kindly help NRF24L01+
that one "more flexible install" can keep antenna inside devo shell? as per A7105 module?. would be great
my devo with A7105 and 3 way switch
Last edit: 19 Sep 2016 08:22 by kaligola.
- RoGuE_StreaK
19 Sep 2016 09:51 #54030
by RoGuE_StreaK
Yep. If you search on banggood for the separate bits (module + antenna) you can get it for a few bucks cheaper.
- kaligola
19 Sep 2016 10:51 - 19 Sep 2016 10:52 #54031
by kaligola
Last edit: 19 Sep 2016 10:52 by kaligola.
Time to create page: 0.694 seconds
- kindly help NRF24L01+
