NRF24L01 stability issue with 7e
20 Sep 2016 01:32 #54047 by epilot
NRF24L01 stability issue with 7e was created by epilot
Hi All,
I have added a NRF24L01 module in my 7e and it only sort of works. I can bind with a Hisky receiver but the signal seems very flaky for lack of a better description. Servos sometimes move delayed. Same RX is rock solid on my Devo 10 with a 3in1 board.
This is the module I added: www.banggood.com/1100-Meter-Long-Distanc...tenna-p-1057170.html
Are there any know quality issues?
21 Sep 2016 22:33 #54112 by mwm
Replied by mwm on topic NRF24L01 stability issue with 7e
Double check to make sure you have an LNA and are using the proper wiring for the version of deviation you are using. There are known problems with some protocols and a missing/unpowered LNA that match what you're seeing.
21 Sep 2016 22:48 #54116 by epilot
Replied by epilot on topic NRF24L01 stability issue with 7e
Many thanks for your response. I'm becoming increasingly convinced there is an issue with the module. I'm going to bin it and install a 3in1 module I have just received. I recently installed one of those in my Devo 10 and it works perfectly.
Time to create page: 0.691 seconds
