Deviation update on Devo7E went wrong :/
26 Sep 2016 13:45 - 26 Sep 2016 16:01 #54287 by KiDuLt
Hi everyone,
I'm using a Devo 7E, and the only mod done to it was the range mod.
I followed instructions today to upgrade to Deviation 5.0.
Now when I turn on my transmitter, a message says that the modules installed aren't OK. (I haven't installed any)
There is no vibrator anymore.
The version still says 4.1 and not 5.0 :(
What did I do wrong ?
QUICK EDIT :
I also copied my model file, but can't bind to my quad anymore :/
I basically ruined my Devo 7E with this update and can't use it anymore.
Any help would be really appreciated !
Last edit: 26 Sep 2016 16:01 by KiDuLt.
26 Sep 2016 16:28 #54291 by HappyHarry
Replied by HappyHarry on topic Deviation update on Devo7E went wrong :/
if it still says 4.1 then you haven't updated the firmware, read the manual on how to install deviation as you need to do more than just copy across the files onto the drive, you need to flash the firmware using dfuse or the java flasher
26 Sep 2016 16:41 - 26 Sep 2016 16:56 #54292 by KiDuLt
Replied by KiDuLt on topic Deviation update on Devo7E went wrong :/
Thank you HappyHarry for your answer.
It's ALL GOOD. Thank you for your time, your work, and thanks to anyone who worked onto this and made Devo users like me super happy !
Last edit: 26 Sep 2016 16:56 by KiDuLt.
27 Sep 2016 00:09 #54309 by HappyHarry
glad to hear you got it worked out bud 8)
27 Sep 2016 08:04 #54320 by Thomas.Heiss
Replied by Thomas.Heiss on topic Deviation update on Devo7E went wrong :/
Don't forget to copy over all 5.0.0 protocol files in USB mode!
27 Sep 2016 13:41 #54334 by KiDuLt
All good Thomas thanks I did copy everything.
Now I'm gonna solder a 3 in 1 module and an antenna, build a china whoop E010, and be happy :D
Time to create page: 0.410 seconds
