Problème batterie DEVO12S ?
01 Oct 2016 20:28 #54478 by Franck
Problème batterie DEVO12S ? was created by Franck
Est ce un problème de batterie ou autre chose, merci.
Is this a battery problem or something, thank you.
Vidéo :
01 Oct 2016 21:25 #54479 by Arnold
Replied by Arnold on topic Problème batterie DEVO12S ?
No video.
I see only a black box containing the words, "Blocked Plugin".
02 Oct 2016 05:54 - 02 Oct 2016 06:38 #54494 by Alexandro
Replied by Alexandro on topic Problème batterie DEVO12S ?
On some Modules like Frsky it can be very jumpy. Try the Test on dsm2 . May be some Overload on the main Voltage Regulator.Most time with the cc2500. Some one used a dc to dc converter to power the modules on the 1 s Lipo Tx Vesions to get a relatively stabel Voltage
Last edit: 02 Oct 2016 06:38 by Alexandro.
02 Oct 2016 06:48 #54500 by Franck
Replied by Franck on topic Problème batterie DEVO12S ?
Alexandro wrote: On some Modules like Frsky it can be very jumpy. Try the Test on dsm2 . May be some Overload on the main Voltage Regulator.Most time with the cc2500. Some one used a dc to dc converter to power the modules on the 1 s Lipo Tx Vesions to get a relatively stabel Voltage
test on DSM2, idem. When y touch the screen the voltage down.
I will try a full discharge on my lipo charger to see.
02 Oct 2016 12:23 #54504 by Franck
I just made a complete discharge, I unloaded 2700mAh.
02 Oct 2016 20:04 #54521 by Franck
I recharge 2730mAh
Is there a difference between the charger and USB charging ?
With USB Charging i can't go to 4,2 v (4,12v max)
04 Oct 2016 07:24 - 04 Oct 2016 07:26 #54573 by Alexandro
i don't know about the 12, but some inside Charger do not charge to 4.2 because the Cycle Live is longer below 4.2
-> 4.2 V around 350 Cycle
-> 4.1 V around 1000 Cycle
on normal Lipos ( thumb rule)
may be here is the same Thing done to get more Cycles out of the Lipo
but if your Lipo getting old the internal resistance is getting higher ,then it charge to 4.2 and some seconds after the full charge it drops fast to a lower Voltage.
If i do testing my Charger i measure the cut off Voltage at the charge State and there it should stay at 4.2 or a little lower at the End.
btw . a Lion Batt is full at 4.15 ! Only Lipo is 4.2 <- care full here to not kill your Batt
only my 2 ct.
greeting Alex
Last edit: 04 Oct 2016 07:26 by Alexandro.
05 Oct 2016 13:50 #54629 by mdmbc
Replied by mdmbc on topic Problème batterie DEVO12S ?
Mine does the same thing. I always just assumed it was a software quirk. It hasn't seemed to hurt anything on mine.
06 Oct 2016 03:11 #54642 by Franck
mdmbc wrote: Mine does the same thing. I always just assumed it was a software quirk. It hasn't seemed to hurt anything on mine.
Quelle tension d'alarme as tu mis ?
What did you voltage alarm set ?
06 Oct 2016 17:50 #54666 by mdmbc
3.6V.
06 Oct 2016 18:39 #54674 by Franck
mdmbc wrote: 3.6V.
Ok ! by default it is 4v
how long she works ?
06 Oct 2016 19:30 #54679 by mdmbc
Can't say I've payed enough attention to time it.. But it has no trouble lasting a full day of flying. I've got two batteries, and have only had to use the second when I forget to charge the one in the transmitter. I bought my second battery from here: www.dx.com/p/walkera-bt3000-3-7v-3000mah...evo-f12-black-331708
Time to create page: 0.266 seconds
