Devo 7e power on issue
- joelones
17 Oct 2016 15:57 - 17 Oct 2016 15:58 #55057
by joelones
Devo 7e power on issue was created by joelones
I was wondering if anybody could please chime in. I installed v5 and installed the nRF24L01 chip and it seems to work fine.
What I've been noticing is sometimes the devo 7e fails to turn on, or more specifically, if I quickly power cycle, ie: turn off and turn on it does not start. Screen is off. Nothing. But if I turn off and wait a few seconds, and then turn on, it's fine. Is this normal behaviour after installing a chip? Or is something wrong here?
My solder job looks decent, at least to me, and I don't think I burnt anything.
imgur.com/a/EUkBo
Thoughts
imgur.com/a/EUkBo
Thoughts
Last edit: 17 Oct 2016 15:58 by joelones.
- aMax
17 Oct 2016 16:34 #55058
by aMax
Replied by aMax on topic Devo 7e power on issue
First try to solder a resitor (20-22K) between VCC and CE (pin2 and pin3), no direct shorting these pins. This may help.
Without this resistor, my screen was sometimes messed up after boot..
- joelones
17 Oct 2016 16:42 #55059
by joelones
Just to clarify, pins 2 (3.3V) & 3 (CE) on the nRF24L01 chip? I neglected to mention that I did short pins 2 & 3 on the chip instead of connected CE to VCC on the CYRF.
Replied by joelones on topic Devo 7e power on issue
aMax wrote: First try to solder a resitor (20-22K) between VCC and CE (pin2 and pin3), no direct shorting these pins. This may help.
- aMax
17 Oct 2016 17:27 #55060
by aMax
On the NRF pcb.
- joelones
17 Oct 2016 17:34 #55061
by joelones
Ok thanks. So you suggest to do both? Remove shorting of pins 2 & 3 and also add resistor?
aMax wrote: On the NRF pcb.
- aMax
17 Oct 2016 17:40 - 17 Oct 2016 17:44 #55062
by aMax
Resistor only, works as a pullup. ( and current limiter).
Edit: ... any reason you did not use GND from the HF part (CYRF) but soldered it to the main pcb?
Last edit: 17 Oct 2016 17:44 by aMax.
- joelones
17 Oct 2016 17:57 #55065
by joelones
Ok, I'll try the resistor on the nrf pcb and keep the short.
As for the GND, I figured one less wire on the CYRF so when it comes time to add the CC2500, I'd connect its ground there. But I admit, I generally don't know what I'm doing.
aMax wrote: Resistor only, works as a pullup. ( and current limiter).
- Deal57
17 Oct 2016 20:08 #55069
by Deal57
Replied by Deal57 on topic Devo 7e power on issue
When I first added my NRF my 7e did this. I later added an A7105 and also changed the ground to pin 7 on the CYRF. It has worked correctly ever since.
- joelones
17 Oct 2016 20:19 - 17 Oct 2016 20:21 #55070
by joelones
Thanks, that's good to know. Perhaps I'll wait for the cc2500 to arrive and do the same with the ground pin.
Deal57 wrote: When I first added my NRF my 7e did this. I later added an A7105 and also changed the ground to pin 7 on the CYRF. It has worked correctly ever since.
Last edit: 17 Oct 2016 20:21 by joelones.
- aMax
17 Oct 2016 20:33 #55071
by aMax
Ohms law...parallel.resistance will stay at 0 Ohm
The currend will flow through the short (0 Ohm) as if the resistor would not be present.
Time to create page: 0.873 seconds
- Devo 7e power on issue
