Devo 7e power on issue
17 Oct 2016 15:57 - 17 Oct 2016 15:58 #55057 by joelones
Devo 7e power on issue was created by joelones
I was wondering if anybody could please chime in. I installed v5 and installed the nRF24L01 chip and it seems to work fine.
What I've been noticing is sometimes the devo 7e fails to turn on, or more specifically, if I quickly power cycle, ie: turn off and turn on it does not start. Screen is off. Nothing. But if I turn off and wait a few seconds, and then turn on, it's fine. Is this normal behaviour after installing a chip? Or is something wrong here?
My solder job looks decent, at least to me, and I don't think I burnt anything.
imgur.com/a/EUkBo
Thoughts
Last edit: 17 Oct 2016 15:58 by joelones.
17 Oct 2016 16:34 #55058 by aMax
Replied by aMax on topic Devo 7e power on issue
First try to solder a resitor (20-22K) between VCC and CE (pin2 and pin3), no direct shorting these pins. This may help.
Without this resistor, my screen was sometimes messed up after boot..
17 Oct 2016 16:42 #55059 by joelones
Replied by joelones on topic Devo 7e power on issue
aMax wrote: First try to solder a resitor (20-22K) between VCC and CE (pin2 and pin3), no direct shorting these pins. This may help.
Just to clarify, pins 2 (3.3V) & 3 (CE) on the nRF24L01 chip? I neglected to mention that I did short pins 2 & 3 on the chip instead of connected CE to VCC on the CYRF.
17 Oct 2016 17:27 #55060 by aMax
On the NRF pcb.
17 Oct 2016 17:34 #55061 by joelones
aMax wrote: On the NRF pcb.
Ok thanks. So you suggest to do both? Remove shorting of pins 2 & 3 and also add resistor?
17 Oct 2016 17:40 - 17 Oct 2016 17:44 #55062 by aMax
Resistor only, works as a pullup. ( and current limiter).
Edit: ... any reason you did not use GND from the HF part (CYRF) but soldered it to the main pcb?
Last edit: 17 Oct 2016 17:44 by aMax.
17 Oct 2016 17:57 #55065 by joelones
aMax wrote: Resistor only, works as a pullup. ( and current limiter).
Ok, I'll try the resistor on the nrf pcb and keep the short.
As for the GND, I figured one less wire on the CYRF so when it comes time to add the CC2500, I'd connect its ground there. But I admit, I generally don't know what I'm doing.
17 Oct 2016 20:08 #55069 by Deal57
Replied by Deal57 on topic Devo 7e power on issue
When I first added my NRF my 7e did this. I later added an A7105 and also changed the ground to pin 7 on the CYRF. It has worked correctly ever since.
17 Oct 2016 20:19 - 17 Oct 2016 20:21 #55070 by joelones
Deal57 wrote: When I first added my NRF my 7e did this. I later added an A7105 and also changed the ground to pin 7 on the CYRF. It has worked correctly ever since.
Thanks, that's good to know. Perhaps I'll wait for the cc2500 to arrive and do the same with the ground pin.
Last edit: 17 Oct 2016 20:21 by joelones.
17 Oct 2016 20:33 #55071 by aMax
This does not make any sense.
Ohms law...parallel.resistance will stay at 0 Ohm
The currend will flow through the short (0 Ohm) as if the resistor would not be present.
Time to create page: 0.314 seconds
