A7105 module range Devo 7E
- joelones
05 Nov 2016 15:15 #55717
by joelones
A7105 module range Devo 7E was created by joelones
I just installed the A7105 module and bound the Devo 7E with a FS-IA6B using ibus.
I'm using the module XL7105-D03 which does include the PA correct? Hence I need to add that to the hardware.ini file.
I chopped the end connector from this antenna and soldered the center wire to the A7105 and shielded portion to the sides.
I'm just curious what kind of range I can expect without adding an external antenna.
Thanks.
Thanks.
- ajtank
05 Nov 2016 15:47 #55718
by ajtank
Replied by ajtank on topic A7105 module range Devo 7E
It should have an integrated PA, read
here
- joelones
18 Nov 2016 18:06 #56010
by joelones
Replied by joelones on topic A7105 module range Devo 7E
As a noob, what would be the best method to test the range with this current setup?
Time to create page: 0.049 seconds
- A7105 module range Devo 7E
