Cheapest upgrade to 8ch from a Devo7E
01 Dec 2016 13:54 - 01 Dec 2016 16:04 #56409 by Ssayer
Probably been asked before, but I must not be using the search well enough. I'm starting to think that maybe it's time to "upgrade?" from my Devo7E. It looks like the memory limitations of the 7E are becoming a drawback. What's my best (cheapest) path to move up?
Last edit: 01 Dec 2016 16:04 by Ssayer. Reason: Always learning...
01 Dec 2016 16:21 #56412 by Nitro_123
Replied by Nitro_123 on topic Cheapest upgrade to 8ch from a Devo7E
Find someone who can replace the processor in yours.
Mobile repair shops or your local hackerspace are good starters
Then add three way switches and pots and the multimodule
Why upgrade ;)
Or just buy a Taranis
01 Dec 2016 16:34 #56413 by hexfet
Replied by hexfet on topic Cheapest upgrade to 8ch from a Devo7E
You don't need to upgrade just for 8 channels. Deviation gives you 12 channels of DSM even on the 7e.
01 Dec 2016 16:36 #56414 by Nitro_123
True. You can assign Trims to those channels iirc or do the switches mod for more functionality.
03 Dec 2016 17:17 - 03 Dec 2016 17:20 #56486 by HappyHarry
Replied by HappyHarry on topic Cheapest upgrade to 8ch from a Devo7E
as nitro_123 and hexfet already mentioned all deviation tx's are 12ch capable, so if you only require the easy use of 1 more channel add the 2x2way or 2x3way switch mods to your 7e or utilise the trim switches, but if the memory capacity and that no new features will be added to the stock 7e is more your worry then the upgrade of the mcu to make an ultimate7e is the best option, due to the extra code space this upgrade allows it means that the addition of up to 8 extra switches and 2 pots and also the voice mod capability are available to use, also giving the same code space as a devo10 means that there will be space for the new features and additions that will come in the future. another option if you want to stay with deviation is to wait a little while and get an at9 when the hardware and code is ready for proper use, or a devo10 or devo8s. otherwise i'd also echo nitro_123 and say go for a taranis :)
Last edit: 03 Dec 2016 17:20 by HappyHarry.
Time to create page: 0.227 seconds
