safety warning..
- magic_marty
23 Dec 2016 13:50 #57152
by magic_marty
safety warning.. was created by magic_marty
I had to change the channel order on a 9ch dsm2 rx using sbus while setting up a pixhawk on a plane and now every time i turn of the tx i get the "Warning ch1 is at 0 safety is -100" pop up...Is there any way to disable this warning from popping up every time i turn on my tx?
Thanks all...
<Marty>
Thanks all...
<Marty>
23 Dec 2016 14:24 - 23 Dec 2016 14:26 #57153
Replied by vlad_vy on topic safety warning..
Try to edit model.ini file.
By default:
[safety]
Auto=min
try to use:
[safety]
Auto=zero
For instance, you can write in the model.ini file: THOLD0 = min FMODE0 = min to get the heli settings you want or you could do: THR = min to get the airplane settings you want.
Can be: "none", "min", "zero", "max"
I have for heli:
[safety]
Auto=min
RUD DR1=min
FMODE1=min
FMODE2=min
By default:
[safety]
Auto=min
try to use:
[safety]
Auto=zero
I have for heli:
[safety]
Auto=min
RUD DR1=min
FMODE1=min
FMODE2=min
Last edit: 23 Dec 2016 14:26 by vlad_vy.
- magic_marty
23 Dec 2016 22:38 - 24 Dec 2016 06:56 #57177
by magic_marty
Replied by magic_marty on topic safety warning..
Hey thanks i set the Auto=zero like you suggested and it no longer pops up warning when powering on the tx..
Cheers!!
EDIT: It works until i have to trim the Ail then it starts to pop back up again cause it changes the value of stick center ...Is there any way to completely remove the safety warning in the model.ini file ? With this plane it wont spin up unless i hold full right RD to arm the FC so no harm in removing the safety completely...
Cheers!!
Last edit: 24 Dec 2016 06:56 by magic_marty. Reason: added question
24 Dec 2016 08:35 #57191
Replied by FDR on topic safety warning..
Guess what: delete the safety section from the model.ini file!
- magic_marty
25 Dec 2016 02:57 #57222
by magic_marty
Resolved...I changed the safety value to "none" and it stopped the pop ups...
Thanks all and Merry Xmas!!
<Marty>
<Marty>
Time to create page: 0.071 seconds
- safety warning..
