Devo f 12e
25 Dec 2016 21:46 #57236 by mcfrob
Devo f 12e was created by mcfrob
I have a Devo f 12e I have updated the firmware but I can not upload the model data for the walkera x350 pro, the error I'm getting is "unable to find date for the device/target"
I've checked the drivers in device manager but still I am stuck.
Please help!
25 Dec 2016 22:07 #57237 by FDR
Replied by FDR on topic Devo f 12e
Are you using the stock Walkera devention firmware or have you already changed it to deviation?
25 Dec 2016 23:15 #57238 by mcfrob
Replied by mcfrob on topic Devo f 12e
I'm new to this but I can tell you I downloaded it from UCDRONE.
does that help?
26 Dec 2016 03:48 #57243 by vlad_vy
Replied by vlad_vy on topic Devo f 12e
Do you try to upgrade model file at "Config" tab?
26 Dec 2016 09:43 #57244 by mcfrob
Yes, I select the file in the config tab and it states the file is successfully loaded. I then click upgrade to upgrade the model data to the transmitter and it says "unable to find data for that device/target in file" and does no upgrade.
26 Dec 2016 11:19 #57245 by Artus
Replied by Artus on topic Devo f 12e
I have a F12E to in worst case i try to help you.
Try to use the Version 1.5 (A or B - depends on your F12E) from walkera-fun page
I have read that the 1.6 is reduced to RTF for special models
In this zip file is also the bin file for the x350Pro
Align TREX 100 (3) Hubsan Q4
Walkera QRX 350 PREMIUM
26 Dec 2016 11:53 #57246 by mcfrob
Thank you I really appreciate some help with this issue.
I started by using the 1.6 and after some research I tried 1.5A and 1.5B. Each version I try I then go to config tab and input the bin file for the x350 pro, it says file loaded successfully but when I click upgrade it states "unable to find data for that device/target in file"
I'm really stuck
26 Dec 2016 14:15 #57248 by Artus
ok - so i will do the same - but version 1.6 is restricted.
I will try this form walkera.fun page downloaded version of 1.5 B - cause i have the 10mW version in test for Deviation software.
I need some time to change back to Walkera firmware. I will tell you my results
26 Dec 2016 14:48 #57249 by Artus
Now - i am back
I used all files from walker-fun page - there is a section "download - Transmitter - F12E - and a zip file for version 1.5 this zipfile contains a X350Pro bin :)
I changed form deviation to walkera firme using devodfuse (also available at this page)
I first install - the firmware with "power on" and "ext" button. After installing the firmware i startet the TX - (throttle warning - cause i am using Mode 2) pull down this stick helps quick.
Then going back in dfu mode (power on and ext) - using in devodfu "config" tab - section of "Upgrade and verify) "...." loading the X350pro file with "open" and starting the Upgrade
After starting the TX - the is the X350Pro :) (but i see there are a lot of restrictions)
This is what i am doing.
Are you able to download - this files - from walkera-fun ?
If not i try to send you here as attachment
26 Dec 2016 15:15 #57250 by mcfrob
Thank you very much for your time with this issue. Would you mind leaving a link to the walkera-fun page as I'm not 100% sure I'm on the correct page.
Thanks again
26 Dec 2016 16:05 #57252 by vlad_vy
26 Dec 2016 16:37 #57254 by Artus
You can start with walkera-fans.de and transmit the page to english
Here is the link with the all file for the F12E - and i use the V1.5 which contains firmware and bin for the x350pro
walkera-fans.de/category/sender-modelleinstellungen/devo-f12e/
If you have further problems - send a screenshot of dfuse where i can see if your transmitter is correctly recognized.
26 Dec 2016 17:32 #57258 by mcfrob
No luck. I've tried upgrading the model data in both 1.5A and 1.5B but I'm still getting the same error message
26 Dec 2016 18:24 #57260 by Artus
Can you send me a screenshot of your dfuse please ?
Time to create page: 0.513 seconds
