Devo f 12e
- mcfrob
25 Dec 2016 21:46 #57236
by mcfrob
Devo f 12e was created by mcfrob
I have a Devo f 12e I have updated the firmware but I can not upload the model data for the walkera x350 pro, the error I'm getting is "unable to find date for the device/target"
I've checked the drivers in device manager but still I am stuck.
Please help!
Please help!
25 Dec 2016 22:07 #57237
Replied by FDR on topic Devo f 12e
Are you using the stock Walkera devention firmware or have you already changed it to deviation?
- mcfrob
25 Dec 2016 23:15 #57238
by mcfrob
Replied by mcfrob on topic Devo f 12e
I'm new to this but I can tell you I downloaded it from UCDRONE.
does that help?
does that help?
26 Dec 2016 03:48 #57243
Replied by vlad_vy on topic Devo f 12e
Do you try to upgrade model file at "Config" tab?
- mcfrob
26 Dec 2016 09:43 #57244
by mcfrob
Yes, I select the file in the config tab and it states the file is successfully loaded. I then click upgrade to upgrade the model data to the transmitter and it says "unable to find data for that device/target in file" and does no upgrade.
- Artus
26 Dec 2016 11:19 #57245
by Artus
Align TREX 100 (3) Hubsan Q4
Walkera QRX 350 PREMIUM
Replied by Artus on topic Devo f 12e
I have a F12E to in worst case i try to help you.
Try to use the Version 1.5 (A or B - depends on your F12E) from walkera-fun page
I have read that the 1.6 is reduced to RTF for special models
In this zip file is also the bin file for the x350Pro
- mcfrob
26 Dec 2016 11:53 #57246
by mcfrob
Thank you I really appreciate some help with this issue.
I started by using the 1.6 and after some research I tried 1.5A and 1.5B. Each version I try I then go to config tab and input the bin file for the x350 pro, it says file loaded successfully but when I click upgrade it states "unable to find data for that device/target in file"
I'm really stuck
I'm really stuck
- Artus
26 Dec 2016 14:15 #57248
by Artus
ok - so i will do the same - but version 1.6 is restricted.
I will try this form walkera.fun page downloaded version of 1.5 B - cause i have the 10mW version in test for Deviation software.
I need some time to change back to Walkera firmware. I will tell you my results
- Artus
26 Dec 2016 14:48 #57249
by Artus
Now - i am back
I used all files from walker-fun page - there is a section "download - Transmitter - F12E - and a zip file for version 1.5 this zipfile contains a X350Pro bin
I changed form deviation to walkera firme using devodfuse (also available at this page)
I first install - the firmware with "power on" and "ext" button. After installing the firmware i startet the TX - (throttle warning - cause i am using Mode 2) pull down this stick helps quick.
Then going back in dfu mode (power on and ext) - using in devodfu "config" tab - section of "Upgrade and verify) "...." loading the X350pro file with "open" and starting the Upgrade
After starting the TX - the is the X350Pro
(but i see there are a lot of restrictions)
This is what i am doing.
Are you able to download - this files - from walkera-fun ?
If not i try to send you here as attachment
- mcfrob
26 Dec 2016 15:15 #57250
by mcfrob
Thank you very much for your time with this issue. Would you mind leaving a link to the walkera-fun page as I'm not 100% sure I'm on the correct page.
Thanks again
Thanks again
- Artus
26 Dec 2016 16:37 #57254
by Artus
You can start with walkera-fans.de and transmit the page to english
Here is the link with the all file for the F12E - and i use the V1.5 which contains firmware and bin for the x350pro
walkera-fans.de/category/sender-modelleinstellungen/devo-f12e/
If you have further problems - send a screenshot of dfuse where i can see if your transmitter is correctly recognized.
- mcfrob
26 Dec 2016 17:32 #57258
by mcfrob
No luck. I've tried upgrading the model data in both 1.5A and 1.5B but I'm still getting the same error message
- Artus
26 Dec 2016 18:24 #57260
by Artus
Can you send me a screenshot of your dfuse please ?
Time to create page: 0.152 seconds
- Devo f 12e
