RSSI Channel 9 on devo 10 with frsky problem
28 Dec 2016 16:52 #57303 by kimman1
I'm using devo 10 with CC2500 module for frsky reciever ( F801 ). My rx has RSSI on SBUS is channel 9. I saw on my TX, Frsky protocol has just 8 channels. I try increasing the channel but have nothing, the maximum channel just 8 channels. What should i do now ?
28 Dec 2016 18:33 - 28 Dec 2016 19:13 #57305 by aMax
Will be selected in the CL/Betaflight configurator! >>>receiver section.
This is not a steering signal channel and the SBus should be found on a tx output, if you have one, and not on the PWM
pins as CPPM.
Edit: However, on the telemetry page rssi should show up if you have this configured right.
Which firmware is on the receiver?
Check this here...
www.rcgroups.com/forums/showthread.php?2...-FrSky-TX-RX-Modules
Last edit: 28 Dec 2016 19:13 by aMax.
Time to create page: 0.488 seconds
