Devo 12s memory loss
- djsmeegy
29 Dec 2016 11:27 #57320
by djsmeegy
Devo 12s memory loss was created by djsmeegy
Hi guys, I bought Devo 12S and I flashed deviation 5.0.0 everything went well, I copied my old models from Devo 10 and bound with my models..
But I turned on and off my tx and thee times the usb logo came on the screen and I lost all files in devo's memory.
When I plugged it to pc, the drive should be formatted it said.
I tried to reflash deviation again but it still presists.
Do you think that my tx has memory corrupted?
- -=Hubi-Dirk=-
30 Dec 2016 07:12 #57354
by -=Hubi-Dirk=-
Replied by -=Hubi-Dirk=- on topic Devo 12s memory loss
Have you formatted the memory?
- djsmeegy
02 Jan 2017 06:02 #57455
by djsmeegy
Replied by djsmeegy on topic Devo 12s memory loss
Yeah, that's for sure. In case I didnt format the memory, it wouldnt be possible to copy needed files there.
But after few turn-on and off the TX, the memory got lost and I had to format it again...
- -=Hubi-Dirk=-
02 Jan 2017 15:58 #57474
by -=Hubi-Dirk=-
Do you use Quick-Format or Standard? I had a Devo 8s (now 12s) and i remember this problem with my 8s. But i use the standard option to format the drive. After that i never had this problem again.
- djsmeegy
03 Jan 2017 11:27 #57496
by djsmeegy
I formatted it in both ways - Quick and then also Standard. Now I flashed fw 4.0.1 and selectt Standard formatting method of memory.
Everything seems to be OK now.
Later I will flash fw 5.0.0 and will test it again.
Time to create page: 0.599 seconds
- Devo 12s memory loss
