firmware upgrade tool for windows 10?
12 Jan 2017 23:06 - 12 Jan 2017 23:07 #57863 by pbeggs1
firmware upgrade tool for windows 10? was created by pbeggs1
as i try to upgrade to be able to use my devo 10 with freshly installed 4in1 module i have found that the software doesn't seem to be useable with windows 10,.. anybody know of a version or a workaround ? or know what im doing wrong,.....
Last edit: 12 Jan 2017 23:07 by pbeggs1. Reason: typo
12 Jan 2017 23:31 #57864 by Deal57
Replied by Deal57 on topic firmware upgrade tool for windows 10?
Can you give us a bit more info? Do you mean DFUse, or do you mean the java tool? With either one you may need a different DFU driver.
When you plug in the Devo in programming mode, do you get a windows driver tone? Can you tell which USB device or connection is used?
Depending on what you get you may need to to use a utility to change driver, so let us know.
13 Jan 2017 02:57 #57870 by pbeggs1
Replied by pbeggs1 on topic firmware upgrade tool for windows 10?
im trying to use DFUse i read about drivers but cant find how to install them (or a driver for) windows 10,
i take and boot up my devo 10 in dfu mode (ext button) it says it is in program update,.. cant find any indication of a connection in windows,
13 Jan 2017 16:13 - 13 Jan 2017 16:14 #57897 by HappyHarry
Replied by HappyHarry on topic firmware upgrade tool for windows 10?
you need to open the device manager in windows and look for what driver windows is loading for the transmitter when it's in programming mode, sometimes it chooses the wrong driver and dfuse wont work. if that's the case you need to then manually load the correct driver which is found in the walkera dfuse program folder on the hard drive
Last edit: 13 Jan 2017 16:14 by HappyHarry.
Time to create page: 0.185 seconds
