Question on wiring CC2500 (Aliexpress)
- StuartAmbient
28 Jan 2017 01:36 - 28 Jan 2017 01:37 #58457
by StuartAmbient
Question on wiring CC2500 (Aliexpress) was created by StuartAmbient
I was looking over here and it didn't match
www.deviationtx.com/wiki/modulelist
the PhracturedBlue pages exactly regarding the wiring for the CC2500 (Aliexpress version) . It's probably just formatting but I still connect 5 -> 10 and 7 -> 9 ?
Last edit: 28 Jan 2017 01:37 by StuartAmbient. Reason: Typo
- Deal57
28 Jan 2017 03:32 #58460
by Deal57
Replied by Deal57 on topic Question on wiring CC2500 (Aliexpress)
If you're using Deviation v5 you need to connect the GDO0 to the LNA_EN and GDO2 to the PA_EN. This allows the protocol software to toggle the Power Amp (On for transmitting, off for receiving) and the Low Noise Amp (off for transmitting, on for receiving). In the modules shown, that's usually pin 5 to 10, pin 7 to 9. If the module is marked, use those markings... it's kind of a trust-but-verify thing, because not all manufacturers seem to be as precise as others.
Feel free to post photos: we'd need to clearly see the back and front of the module.
- StuartAmbient
28 Jan 2017 13:20 #58469
by StuartAmbient
Replied by StuartAmbient on topic Question on wiring CC2500 (Aliexpress)
The pins are marked on the board so those correspond correctly. I use the nightly build but I'll assume that counts as v5 as well.
- Deal57
28 Jan 2017 13:23 #58470
by Deal57
Yes, the nightlies are built on version 5. If it works, can you post the photos in case someone else needs a look?
Happy flying!
Happy flying!
- StuartAmbient
28 Jan 2017 13:42 #58471
by StuartAmbient
Will do! Thank you for the help.
Time to create page: 1.090 seconds
- Question on wiring CC2500 (Aliexpress)
