Help for timer configuration
- schwarzsurfer
28 Jan 2017 18:42 - 28 Jan 2017 18:42 #58481
by schwarzsurfer
Help for timer configuration was created by schwarzsurfer
I want to configure a timer that is only active when the motor of my model is running. I have a model boat, so the throttle stick is in the middle position 0. The timer should count all time the throttle stick is not 0. I didn't find a way to manage this... do you have an idea how to solve this?
Thank you!
Marian
Thank you!
Marian
Last edit: 28 Jan 2017 18:42 by schwarzsurfer.
28 Jan 2017 19:03 #58482
Replied by FDR on topic Help for timer configuration
Use a virtual channel as the switch, which has the throttle as the source and the deadband function in the middle...
- schwarzsurfer
28 Jan 2017 19:14 #58483
by schwarzsurfer
Replied by schwarzsurfer on topic Help for timer configuration
I created the virtual channel with source throttle, assigned the virtual channel to the timer and set the deadband funktion to +/- 3 but the timer still runs all the time...
- schwarzsurfer
28 Jan 2017 19:48 #58487
by schwarzsurfer
hm I can't get it to work
Even if I set the deadband to 20 or so it has no effect. What am I doing wrong? Could you show me a configuration example? That would be great...
Thank you!
Thank you!
28 Jan 2017 20:47 #58493
You are right, it wasn't enough.
I have such a config for a car:
Source: Ch1 (if TAER, or Ch3 in case of AETR or EATR)
Curve: Deadband
Scale: 125
Offset: -100
Curve: Deadband
Scale: 125
Offset: -100
- schwarzsurfer
29 Jan 2017 09:08 #58522
by schwarzsurfer
Thanks, now it works. I don't get why, but it works
Time to create page: 0.188 seconds
- Help for timer configuration
