Rename default channels?
- schwarzsurfer
28 Jan 2017 19:28 #58485
by schwarzsurfer
Rename default channels? was created by schwarzsurfer
is there a way to rename the default channels like RUD, THR, AIL, ELE and so on? I can rename the virtual channels, but I didn't find a way to do the same to the predefined channels...
thank you!
Marian
thank you!
Marian
- schwarzsurfer
28 Jan 2017 21:03 #58497
by schwarzsurfer
Replied by schwarzsurfer on topic Rename default channels?
Ok, thanks.
- Fernandez
01 Feb 2017 22:49 #58629
by Fernandez
Replied by Fernandez on topic Rename default channels?
Yes I also never understood that. why not be able to choose which channel to assign your rudder etc? If it was just ch nr 1-16 etc? Than in the model.ini, could define channel labels ?
- schwarzsurfer
01 Feb 2017 23:10 #58631
by schwarzsurfer
Sounds like a good idea. I even would like to have a model type "car" or "boat" or just "standard" with channel 1-10 to assign them by myself.
Greetings
Greetings
04 Feb 2017 09:27 #58731
Replied by FDR on topic Rename default channels?
We've aready disussed it a few times, and always came to the conclusion, that since the receiver channels are assigned the same way, it would only lead to even more questions and misunderstanding.
Aside from that it would be a lot of work too, because they are widely used across the whole code...
Time to create page: 0.474 seconds
- Rename default channels?
