Rename default channels?
28 Jan 2017 19:28 #58485 by schwarzsurfer
Rename default channels? was created by schwarzsurfer
is there a way to rename the default channels like RUD, THR, AIL, ELE and so on? I can rename the virtual channels, but I didn't find a way to do the same to the predefined channels...
thank you!
Marian
28 Jan 2017 20:41 #58492 by FDR
Replied by FDR on topic Rename default channels?
No, you can't.
28 Jan 2017 21:03 #58497 by schwarzsurfer
Replied by schwarzsurfer on topic Rename default channels?
Ok, thanks.
01 Feb 2017 22:49 #58629 by Fernandez
Replied by Fernandez on topic Rename default channels?
Yes I also never understood that. why not be able to choose which channel to assign your rudder etc? If it was just ch nr 1-16 etc? Than in the model.ini, could define channel labels ?
01 Feb 2017 23:10 #58631 by schwarzsurfer
Sounds like a good idea. I even would like to have a model type "car" or "boat" or just "standard" with channel 1-10 to assign them by myself.
Greetings
04 Feb 2017 09:27 #58731 by FDR
We've aready disussed it a few times, and always came to the conclusion, that since the receiver channels are assigned the same way, it would only lead to even more questions and misunderstanding.
Aside from that it would be a lot of work too, because they are widely used across the whole code...
Time to create page: 0.222 seconds
