Question - Adding Pololu 3.3 Vreg to my 7E
- StuartAmbient
28 Jan 2017 20:01 - 28 Jan 2017 21:14 #58489
by StuartAmbient
Question - Adding Pololu 3.3 Vreg to my 7E was created by StuartAmbient
Last edit: 28 Jan 2017 21:14 by StuartAmbient. Reason: typo
- StuartAmbient
28 Jan 2017 22:02 - 28 Jan 2017 22:15 #58501
by StuartAmbient
Replied by StuartAmbient on topic Question - Adding Pololu 3.3 Vreg to my 7E
There is continuity between the debug gnd and the gnd on the 3 pin header (next to the label Bat). I think I should be okay grounding Pololu to the debug gnd. The CYRF module gnd is not on the same plane.
Last edit: 28 Jan 2017 22:15 by StuartAmbient. Reason: add
- HappyHarry
28 Jan 2017 22:37 #58505
by HappyHarry
Replied by HappyHarry on topic Question - Adding Pololu 3.3 Vreg to my 7E
gnd is shared throughout bud, so you'll be fine using the header or any other gnd position on the pcb
- StuartAmbient
29 Jan 2017 00:56 #58513
by StuartAmbient
Thank you sir, again!
Time to create page: 0.074 seconds
- Question - Adding Pololu 3.3 Vreg to my 7E
