F7 throttle problem + 350 pro + nightly build
31 Jan 2017 17:51 #58596 by Dustalot
I recently upgraded to Deviation nightly build on my Devo F7. I had to use rebind plug to clear and rebind RX703A. When I first arm, the motors will spin up at 1% throttle and hold for a few seconds even when I drop it back down to 0. It will then disarm itself and when I re-arm I only get throttle input at 15% and above and nothing below. I get full range of throttle in ESC calibration mode but when I unplug power and reset it goes back to the problem before...like it isn't saving or something. I've also calibrated from transmitter menu and on Mission Planner. My stock Devo 7 with my X350 profile on it works perfect. My Devo F7 throttle also works perfectly with my other stock x350 pro and receiver. I'm currently trying to learn how to extract the protocol files from devo.fs file with the buildfs.exe in command prompt. Any information would be a huge help. Thank you!
Time to create page: 0.055 seconds
