Using one of the navigation button
- StuartAmbient
05 Feb 2017 19:03 #58788
by StuartAmbient
Using one of the navigation button was created by StuartAmbient
Trying to use a button (in this case the "right") as a momentary. It would act as the "flip" button. Not sure if this is correct but if anyone can offer some feedback it'd be appreciated.
First I went into Trims and added a trim with the src as Virtual1
[trim5]
src=Virt1
pos=Right
step=193
Then into the mixer to setup the virtual channel
[virtchan1]
template=complex
[mixer]
src=Virt1
dest=Virt1
scalar=0
usetrim=0
Finally I want this to operate on Channel 7
[channel7]
template=simple
[mixer]
src=Virt1
dest=Ch7
curvetype=expo
points=0,0
[trim5]
src=Virt1
pos=Right
step=193
[virtchan1]
template=complex
[mixer]
src=Virt1
dest=Virt1
scalar=0
usetrim=0
[channel7]
template=simple
[mixer]
src=Virt1
dest=Ch7
curvetype=expo
points=0,0
- ajtank
06 Feb 2017 04:29 #58798
by ajtank
Replied by ajtank on topic Using one of the navigation button
You can test on the channel monitor option of your transmitter.
By the way you can also read this excellent guide by Deal57.
- StuartAmbient
06 Feb 2017 15:18 #58822
by StuartAmbient
Right, I was thinking to monitor the channel.
Now, I posted the model file but mostly for reference. I used the screens to set things up and will probably stay with that method for the time being.
I followed the manual instructions Advanced Topics / Using a Trim as a Virtual Switch.
The instructions use an actual trim as the example while I am attempting to use one of the buttons. What was confusing then I had the "Trim -" and "Trim +" fields. I only put the button in the Trim+ field and left Trim- none. Not sure if that is wrong.
Then the instructions have setting up the virtual channel as the next step. After doing that the instructions end as completed. Then I went ahead and gave src in Channel 7 to the virtual channel. So far it's not working and I'm not sure why.
Replied by StuartAmbient on topic Using one of the navigation button
ajtank wrote: You can test on the channel monitor option of your transmitter.
Time to create page: 0.578 seconds
- Using one of the navigation button
