Devo 7e missing module error
- Felixxx
08 Feb 2017 11:18 #58919
by Felixxx
Devo 7e missing module error was created by Felixxx
Hi.
I have problems with adding nrf24l01 to my tx.
I already have A7105 and 3x2 switches. A7105 and switches are working great. I can bind to hubsan and scisky FC normally.
But when I power up tx I get message missing module nrf24l01.
My firmware is latest 5.0 and I enabled nrf24l01 in hardware.ini
A7105 use pin TMS and is set to A13.
Nrf24l01 is conect to pin TCK an is set to A14.
If I set A7105 to A14 and nrf24l01 to A13 I get message missing module A7105 when I power up tx.
Does anyone know how can I solve this problem?
- HappyHarry
08 Feb 2017 14:47 #58925
by HappyHarry
Replied by HappyHarry on topic Devo 7e missing module error
if your wiring is ok with no shorts or faulty connections then it's likely you have a faulty module
- Felixxx
08 Feb 2017 18:33 #58938
by Felixxx
Replied by Felixxx on topic Devo 7e missing module error
I just desolder and solder all wires again and I don't have error at power up any more. Strange but ok
One more question. Every time when I want to change anything via usb I have to format tx folder and upload new files. I can't just edit them at tx folder. Why?
And tnx for help
And tnx for help
- HappyHarry
08 Feb 2017 20:00 #58946
by HappyHarry
good to hear bud, for editing if you are using wordpad or windows notepad it changes the file structure to one that isn't supported by the firmware, always edit any of the files with something like notepad++ >>
notepad-plus-plus.org/
and you should have no more file editing issues
Time to create page: 0.292 seconds
- Devo 7e missing module error
