max throttle
15 Feb 2017 04:15 #59150 by 3dfixer
max throttle was created by 3dfixer
got a flashed devo 7e and am having trouble with max output. connects to my models fine but when i check reciever settings in betaflight, i cant get upper limit past 1893. tried maxing out scale etc on tx but cant get higher. hence i pitch/roll faster one way than the other. also cant get full throttle. any ideas??
tony
15 Feb 2017 14:03 #59153 by Deal57
Replied by Deal57 on topic max throttle
In CF/BF the rxrange command will help normalize the endpoints from the normal Devo range -- for mine it seems to be 1159 to 1841 -- to the 1000 to 2000 range CF/BF are designed around (e.g. rxrange 0 1159 1841). I've read what seem to be conflicting accounts as to whether it's better to use subtrims or scale, or if the rxrange is more desireable, but for me it works brilliantly.
Time to create page: 0.024 seconds
