Eachine micro FrSky receivers
06 Mar 2017 18:39 - 06 Mar 2017 22:07 #59917 by Fallingwater
Eachine micro FrSky receivers was created by Fallingwater
I have a QX90C, a X73 and a X73S all with FrSky receivers.
I've been trying to get the QX90C going (the others will come later) with my Devo 10+4-in-1, but no luck so far.
I *think* I managed to bind it by shorting the bind pins and using the Frsky protocol, since now the LED turns solid when I turn on the TX and flashes when I turn it off. However, I've no idea how to arm it. I tried figuring it out from the Cleanflight configurator, but all it shows in the receiver tab is this - ever, with no change at all no matter how much I twiddle the sticks or indeed if I turn off the transmitter altogether.
I can confirm that both the Devo and the 4-in-1 work correctly as I'm already flying my Eachine E010 and H8 Mini with it.
Last edit: 06 Mar 2017 22:07 by Fallingwater.
06 Mar 2017 18:55 #59919 by Fernandez
Replied by Fernandez on topic Eachine micro FrSky receivers
There are 3 different Frsky protocols. (or actually 4 as X series protocol has 2 options FCC and EU mode) Make sure you are selecting D series protocol.
06 Mar 2017 22:04 - 06 Mar 2017 22:04 #59932 by Fallingwater
Replied by Fallingwater on topic Eachine micro FrSky receivers
I'm not sure which protocol the D series is. I have Frsky, Frsky-V8 and FrskyX, the latter as you say with FCC and EU mode. Of these, Frsky seems to be the only one to register any change on the bind LED.
Last edit: 06 Mar 2017 22:04 by Fallingwater.
Time to create page: 0.092 seconds
