extra-switches on Devo7e not recognized
08 Mar 2017 17:42 #60005 by enordaton
extra-switches on Devo7e not recognized was created by enordaton
Using Devo7e with Deviation 5.0 Installed 2 ON OFF ON 3way toggles using instuctions from the wiki by straferr. Used 1n4148 diodes with band toward switch. followed wiring per wiki. edit hardware ini with notepad++ to read extra-switches=3x2. cannot see switches in monitor. Checked diodes with meter ok and checked wiring for shorts and continuity. What is next step?
08 Mar 2017 18:20 - 08 Mar 2017 18:21 #60007 by Moeder
Replied by Moeder on topic extra-switches on Devo7e not recognized
Most common mistake: Did you forget to remove the colon (";") in front of extra-switches?
Last edit: 08 Mar 2017 18:21 by Moeder.
08 Mar 2017 21:21 #60010 by enordaton
Replied by enordaton on topic extra-switches on Devo7e not recognized
Thanks for response. Followed instructions very carefully, which included removing semicolon in hardware ini. Very frustrating. have searched forum also to see others with same problem. those delt with not using right diodes or the hardware statement. Can't figure this one out.
08 Mar 2017 22:02 #60012 by Moeder
We'll solve it, don't worry.
1.) Do SW A0-2 and SW B0-2 appear in channel monitor (second page, scrolled down)?
2.) if yes, please post pictures of your wiring and soldering job
09 Mar 2017 03:40 #60022 by enordaton
Hold and Fmode are the only switches in scroll down. I have to set up to take some pics.get them on here tomorrow.
09 Mar 2017 10:33 #60028 by mwm
Replied by mwm on topic extra-switches on Devo7e not recognized
If the original switches are the only ones in the scroll down, then the hardware.ini file isn't right.
If you post a copy of it, we can figure out what's wrong.
09 Mar 2017 19:06 - 09 Mar 2017 20:34 #60047 by enordaton
here is wiring pics
Last edit: 09 Mar 2017 20:34 by enordaton. Reason: add ini
09 Mar 2017 22:06 #60054 by Moeder
hmm..both soldering and ini content look fine to me, and I'm sure the ini is not named "hardware2.ini" when copied to the tx, or is it?
09 Mar 2017 22:27 #60058 by enordaton
it is not. so what is next suggested step?
10 Mar 2017 02:41 #60071 by mwm
Did you by any chance use notepad instead of notepad++ to edit the file? I thought the issues with not being able to read files edited by notepad had been fixed, but maybe not.
10 Mar 2017 05:18 #60074 by FDR
Replied by FDR on topic extra-switches on Devo7e not recognized
No, the line ends are fine...
10 Mar 2017 07:27 #60075 by enordaton
please see first post, notepad++
10 Mar 2017 08:29 #60078 by Moeder
FDR, maybe there is an issue here? See also this post . It works for me in the emulator though...
10 Mar 2017 09:33 #60080 by FDR
Yes, I saw that, but I don't understand yet.
His file looks OK, but I see CrLf in all the ini files in my Windows based development environment.
Would somebody with a Linux system validate, if he has CrLf or simple Lf at the line endings of those files in his git repository?
10 Mar 2017 09:38 #60081 by FDR
Actually this in on my workplace machine, I think I don't have this problem at home.
It would also explain why I can't compile languages on this machine...
10 Mar 2017 12:43 #60084 by FDR
OK, I found that the repository defines the line endings very loosely:
* text=auto
src/libopencm3/scripts/* eol=lf
*.pl eol=lf
*.py eol=lf
It means, that all our other then .pl and .py text file endings are automatically converted on checkout to the OS defaults, in my case CrLf on Windows.
It is dangerous, because if I compile, all my ini files in the resulting zip file reserve that CrLf line endings!
Shouldn't we change that definition, so to make all the files have Lf line endings?
Do somebody use an editor on Windows, which doesn't support the unix style line endings?
There shouldn't be any...
10 Mar 2017 20:05 - 11 Mar 2017 03:38 #60102 by enordaton
UPDATE: formatted drive and reloaded FW and file system and its fixed.Thank all that responded.File system was reloaded by hand. Must have been corrupted.
Last edit: 11 Mar 2017 03:38 by enordaton. Reason: add text
Time to create page: 0.377 seconds
