Devo s8 upgrad to version 5.0.0
09 Mar 2017 09:17 #60024 by Hr
Hi All
Iinstulled the new ver 5.0.0 but when I look the deviation logo page in the transmitter screen it writen ver 4.0.1
Is it mean the upgrad didnot proccesed
How can I see if the v5.0.0 is instulled in my transmitter?
09 Mar 2017 10:32 #60027 by mwm
Replied by mwm on topic Devo s8 upgrad to version 5.0.0
Check the about page. If that says 4.0.1, you didn't upgrade. If that's the case, tell us exactly what you did and maybe we can figure out what went wrong.
09 Mar 2017 13:51 #60033 by Hr
Replied by Hr on topic Devo s8 upgrad to version 5.0.0
Hi
So I downlowded the deviation-devo8-v5.0.0 zip file
Unziped the file and copied all files to my devo thet was concect to my pc via usb (I could see the old files)
So what I am missinig
09 Mar 2017 15:45 #60036 by Hr
The problem solved, I forgot to Use the dfuse tool for upgrading .
Thank you
13 Mar 2017 13:41 #60170 by Thomas.Heiss
Replied by Thomas.Heiss on topic Devo s8 upgrad to version 5.0.0
Don't install release 5.0.0. Install Vlad's "5.0 with latest releases" test build: www.deviationtx.com/forum/6-general-disc...ring-operation#60167
You can find it in the forum in the "builds" sub-forum. He uploads his compiled ZIP files.
24 Mar 2017 00:40 #60657 by bazsound
Replied by bazsound on topic Devo s8 upgrad to version 5.0.0
Is this just the 8s version, or does it apply to others.
I use devo10 and dsmx protocol..... really do not want to have my 450 come down due to a bug in devaition, shouldnt this really be pushed to a new version of deviation!!!!
24 Mar 2017 16:56 #60693 by mwm
It applies to all versions.
We really need a "stable" build in between "release" and "nightly". It should be the release version + new protocol code (what Vlad is providing) + bug fixes.
24 Mar 2017 17:36 #60696 by Moeder
Replied by Moeder on topic Devo s8 upgrad to version 5.0.0
Then why should we not just have a monthly 5.0.x based on vlads branch?
24 Mar 2017 17:43 - 24 Mar 2017 17:43 #60697 by FDR
Replied by FDR on topic Devo s8 upgrad to version 5.0.0
Actually he is only maintaining the 5.0.0 branch because he doesn't like the new menu system.
He has merged all the changes to that branch except for that...
Last edit: 24 Mar 2017 17:43 by FDR. Reason: typo
24 Mar 2017 17:55 #60699 by Moeder
I personally believe in the nightlies, as they usually are very stable. On the other hand having a bugfix/protocol addition release would only force users to update the firmware dfu and leave the filesystem untouched.
24 Mar 2017 18:01 - 24 Mar 2017 18:02 #60700 by FDR
Not necessarily.
A bug fix might affect the filesystem. Usually not, but it can happen...
Last edit: 24 Mar 2017 18:02 by FDR.
24 Mar 2017 23:57 #60710 by bazsound
Ok ill need to look at this.
discovered today that if my radio is already powered on before the heli, it wont bind (running dsm2) i then have to power cycle the radio before it will connect.
25 Mar 2017 11:21 #60725 by Thomas.Heiss
Always turn on the radio FIRST, then your heli ESC/flight pack!
First turn off your heli, then the radio (if at all).
26 Mar 2017 00:00 #60749 by bazsound
Yes i know this is how it should be done. my point is that i wont get connected if i do it that way. No bind. tx has to be powerccled.
Time to create page: 0.788 seconds
