custom model Icons and Failsafe
- Spyder22
20 Mar 2017 23:17 #60458
by Spyder22
custom model Icons and Failsafe was created by Spyder22
I just built a racing quad and I want to put a failsafe in case the tx gets disconnected, how would I go about doing this in deviation 5.0 on a devo 8s. I also want to use a custom icon for my quad, but im not sure how to make one.
21 Mar 2017 07:07 #60469
Replied by mwm on topic custom model Icons and Failsafe
How you set failsafe depends on the reciever, so you'll need to tell us which Rx you used.
Read the pines forum thread for the icing for format, then copy a file with the appropriate format to the modelico folder on the transmitter.
- Spyder22
21 Mar 2017 10:45 #60472
by Spyder22
Replied by Spyder22 on topic custom model Icons and Failsafe
Im flying a RX701 Devo Reciever
21 Mar 2017 11:09 #60473
Replied by FDR on topic custom model Icons and Failsafe
Then simply set the required value(s) in the fail-safe field on the channel setup page(s)...
- Spyder22
21 Mar 2017 11:12 #60474
by Spyder22
But where is that setup page in the advanced mixer gui? Thats what Im confused on, I can't find it.
21 Mar 2017 11:53 #60475
That is the button in the first column, on which the chanel name is written.
- Spyder22
21 Mar 2017 12:17 #60476
by Spyder22
Found it, Thank You!
Time to create page: 0.126 seconds
- custom model Icons and Failsafe
