custom model Icons and Failsafe
20 Mar 2017 23:17 #60458 by Spyder22
custom model Icons and Failsafe was created by Spyder22
I just built a racing quad and I want to put a failsafe in case the tx gets disconnected, how would I go about doing this in deviation 5.0 on a devo 8s. I also want to use a custom icon for my quad, but im not sure how to make one.
21 Mar 2017 07:07 #60469 by mwm
Replied by mwm on topic custom model Icons and Failsafe
How you set failsafe depends on the reciever, so you'll need to tell us which Rx you used.
Read the pines forum thread for the icing for format, then copy a file with the appropriate format to the modelico folder on the transmitter.
21 Mar 2017 10:45 #60472 by Spyder22
Replied by Spyder22 on topic custom model Icons and Failsafe
Im flying a RX701 Devo Reciever
21 Mar 2017 11:09 #60473 by FDR
Replied by FDR on topic custom model Icons and Failsafe
Then simply set the required value(s) in the fail-safe field on the channel setup page(s)...
21 Mar 2017 11:12 #60474 by Spyder22
But where is that setup page in the advanced mixer gui? Thats what Im confused on, I can't find it.
21 Mar 2017 11:53 #60475 by FDR
That is the button in the first column, on which the chanel name is written.
21 Mar 2017 12:17 #60476 by Spyder22
Found it, Thank You!
Time to create page: 0.507 seconds
