channel mapping wrong
26 Mar 2017 20:22 - 26 Mar 2017 20:49 #60780 by enordaton
channel mapping wrong was created by enordaton
Got the Spektrum Sat bound, had to use the 1024 "workaround". On the radio the sticks show proper output in mixer. In cleanflight all stick movements are wrong. Using Devo7e with v5.0 using attached model where the switch assignments are not yet fixed for my setup
File Attachment:
File Name: model1.ini
File Size:4 KB
TAER is used
Last edit: 26 Mar 2017 20:49 by enordaton.
26 Mar 2017 23:26 #60785 by RobC62
Replied by RobC62 on topic channel mapping wrong
You have a mixer linked to Chan1 with source from Aileron...
[channel1]
scalar=125
template=complex
[mixer]
src=THR
dest=Ch1
switch=RUD DR0
curvetype=9point
points=-100,-75,-50,-25,0,25,50,75,100
[mixer] <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< ????
src=AIL <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
dest=Ch1 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
switch=RUD DR1
offset=-125
curvetype=less-than-0
points=-100
27 Mar 2017 03:58 #60788 by enordaton
Replied by enordaton on topic channel mapping wrong
Thanks for your input. I borrowed a file to try out, not realizing some deficiences for my purpose.
27 Mar 2017 16:12 #60808 by Sero
Replied by Sero on topic channel mapping wrong
Have you played around with the channel map, in the receiver tab? I had to change it to TREA1234 to get the correct result.
27 Mar 2017 18:06 - 27 Mar 2017 19:42 #60816 by enordaton
RobC62 wrote: You have a mixer linked to Chan1 with source from Aileron...
[channel1]
scalar=125
template=complex
[mixer]
src=THR
dest=Ch1
switch=RUD DR0
curvetype=9point
switch=RUD DR1
offset=-125
points=-100
I fixed the 4 main channels and attempted the switches. The main 4 channels now respond in cleanflight, but the switches show NO response.
File Attachment:
File Name: model1_2017-03-27.ini
File Size:4 KB
Last edit: 27 Mar 2017 19:42 by enordaton.
27 Mar 2017 18:36 #60817 by RobC62
Your .ini pic is not showing, but I am assuming you have assigned the relevant switches to the channels your FC needs?
27 Mar 2017 21:26 #60823 by enordaton
Ini file is visible from text and from attachment.
We are using v5.0 Devention and bound to a Lemon Sat thru an xracer Fc. Don't understand why switches not working in Cleanflight
27 Mar 2017 22:13 #60825 by RobC62
I have loaded your .ini onto my 7E and see the following:
Chan 5 you have a 'fixed' curve. Have a look in the 'Transmitter menu > Channel Monitor' screen where you will see changing your HOLD switch does nothing.
Chan 6 and 7 are showing no source, so nothing is moving in the Channel monitor screen again.
30 Mar 2017 20:22 #60951 by enordaton
Found a model.ini that fits my setup.All switches now work in cleanflight. switch program is hard to learn!
Time to create page: 0.884 seconds
