Noob help devo 10 binding
- kkeller416
07 Apr 2017 01:04 #61227
by kkeller416
Noob help devo 10 binding was created by kkeller416
So i purchased a used devo 10 with a zmr250 quad. to fly i would have to turn aux5 until the quad would bind. so it was flying before i crashed and needed to replace a motor and esc. while waiting for esc shipping I installed a new 4in1 chip. so now my other wltoys and jjrc quads bind just fine going thru the menu, however i cant bind my zmr250 quad
can anyone help me figure out how to bind?
i have the devo 10 on deviation 5.0 the quad has a naze32 board updated to the latest cleanflight firmware. i have a cm703 rx connected ppm.
ive tried using cleanflight with cli "set spektrum_sat_bind=9" but it doest seem to bind if i try to bind thru the menu..
can anyone point me in the correct direction?
im not sure if i burned out the rx or control board on the crash.
- Texacate
24 Apr 2017 15:37 - 26 Apr 2017 05:03 #61732
by Texacate
Replied by Texacate on topic Noob help devo 10 binding
Since the CM703 is full size receiver, I would take the RX out and see if you can bind the CM703 to your Devo10 using the bind plug.
The binding options in Cleanflight are geared towards satellite receivers that don't have the pins for a bind plug. Had mixed results binding within Cleanflight.
Last edit: 26 Apr 2017 05:03 by Texacate.
Time to create page: 0.381 seconds
- Noob help devo 10 binding
