Flashed Devo 7E wrong, USB read-only, weird files
04 May 2017 16:34 #61997 by idiot
So like an idiot I skipped over parts of the manual and tried to flash deviation-emu_devo7e-v5.0.0.zip onto my new Devo 7E with the Deviation Updater.
Afterwards it made weird sounds starting up, and after actually reading the manual I flashed deviation-devo7e-v5.0.0.zip, which boots fine,
but the USB drive is strange: Everything is read-only, and there are strange files in the main directory:
-rw-r--r-- 1 username username      16384 Apr 30  2016 DATALOG.BIN
-rw-r--r-- 1 username username       4095 Apr 30  2016 ERRORS.TXT
-rw-r--r-- 1 username username        598 Apr 30  2016 HARDWARE.INI
drwx------ 2 username username       4096 Jan  1  2098 LAYOUT
drwx------ 2 username username       4096 Jan  1  2098 MEDIA
drwx------ 2 username username       4096 Jan  1  2098 MODELICO
drwx------ 2 username username       4096 Jan  1  2098 MODELS
drwx------ 2 username username       4096 Jan  1  2098 PROTOCOL
drwx------ 2 username username       4096 Jan  1  2098 TEMPLATE
-rw-r--r-- 1 username username        351 Apr 30  2016 TX.INI
-r--r--r-- 1 username username 4294967295 Dez 28  2107 ■  ■c   .  ¢
-r--r--r-- 1 username username 4294967038 Aug  1  2107     ■   .
Any chance to fix this?
Cheers.
04 May 2017 16:50 #61998 by joeblack
tried to format the USB drive?
05 May 2017 11:57 #62029 by idiot
I ran the Deviation Uploader again with the 7E firmware and had "Format" ticked, with the problem persisting. Is this what you meant?
05 May 2017 17:07 #62038 by joeblack
No, i thought after firmware uploud right mouse click on the USB drive and try to format with fat like you would format an ordinary USB stick.
08 May 2017 09:53 #62136 by idiot
I'm using Linux, so I used the command line to do it, but if formated the drive as fat. Now the drive is writeable, but although it says there are 2MB free space, I cannot copy the contents of deviation-devo7e-v5.0.0 (minus .zip and .dfu) to it, because it claims insufficient space.
I'm really stuck now.
08 May 2017 15:12 - 08 May 2017 15:29 #62157 by joeblack
It should be OK, the files all together are about 684KB so they must fit!
I checked my Devo 7E and there are also only 2MB so 2MB is totally ok.....
look here and try again (you need only this files/folders - nothing else !!)
https://www.dropbox.com/s/ownxg6ukjj27438/Devo7E_content.jpg?dl=0
greetings
joe
Last edit: 08 May 2017 15:29 by joeblack.
08 May 2017 15:28 #62158 by idiot
So I think I have it fixed now. I seemed to have had the same problem as www.deviationtx.com/forum/6-general-disc...untu?screenMode=none and used the same solution, creating an image with mkfat.py and then just dd-ing it onto the device. It now boots up, and the files are writeable. I suspect that the problem is that Linux wants to create a partition table and then format partitions, but the device needs to be formated as one.
Thank you for your help.
Cheers
08 May 2017 15:30 #62159 by joeblack
perfect - happy flying
Time to create page: 0.494 seconds
