Issues with DSMX?
23 Aug 2017 00:37 - 23 Aug 2017 00:38 #63909 by wasp09
Replied by wasp09 on topic Issues with DSMX?
I received my redcon DSMX satellite tonight. It is the version with the bind button. While BF shows 12 channels but only 10 seems to response to my devo 10. Is that normal?
Do we have some document on the options inside the DSMX box, like what does high speed do, what is F.log filter, how to set up telemetry on the RX side. Even though the default works (10 out 12 channels), it would be nice to be able to use the extras.
Regards,
Last edit: 23 Aug 2017 00:38 by wasp09.
23 Aug 2017 09:05 #63921 by Arakon
Replied by Arakon on topic Issues with DSMX?
BF shows however many channels you set up in BF, completely regardless of the capabilities of the receiver.
23 Aug 2017 13:07 #63924 by wasp09
Is there a limit on the number of channels on a DSMX satellite? Does the TX alone control the number of channels? This satellite actually has a bind button and does not require hooking up with a regular RX to bind.
23 Aug 2017 21:30 #63942 by badfrogg
Replied by badfrogg on topic Issues with DSMX?
Hey everyone, Its been quite a while since I've been here. I have still have my 7e modded with the A7105 and the NRF24L01 and the PA mod for the CYRF6936
I haven't used it in years but was going to give it to a friend who wants to get into RC. I want to give him a plane and was going to set it up with a DSMX receiver.
My question is, what is the most stable combination of firmware and DSMX receiver to use? I dont want him to have any radio troubles... This will be for DSMX/DSM2 only.
24 Aug 2017 04:05 #63945 by hexfet
Replied by hexfet on topic Issues with DSMX?
I use the latest nightly on a Devo 10 with Spektrum DSMX satellites with no issues.
Testing with BF 3.2.1 and these satellites I also see only 10 channels active in the configurator receiver display. Looking at the DSM code it is written to support 12 channels. The number of channels is sent to the receiver in the bind process so it needs to be set to 12 in the model file when binding. There are 12 channels of data on the satellite serial output, verified by looking at the serial data.
Took a quick look at the betaflight spektrum serial code and it is written to support 12 channels. Also tried assigning AUX8 to a function and that didn't work, so it's not just a problem with the receiver display. The docs page seems regularly updated but says just 8 channels are supported. Needs a closer look.
24 Aug 2017 04:30 - 24 Aug 2017 04:31 #63948 by vlad_vy
Replied by vlad_vy on topic Issues with DSMX?
I think it's Betaflight restriction:
set max_aux_channels = 6
4 + 6 = 10
You need at CLI:
set max_aux_channels = 8
save
Last edit: 24 Aug 2017 04:31 by vlad_vy.
24 Aug 2017 11:57 - 24 Aug 2017 11:58 #63961 by hexfet
Thanks, that worked :) Channels 11 and 12 working fine.
Last edit: 24 Aug 2017 11:58 by hexfet.
25 Aug 2017 13:28 - 25 Aug 2017 21:33 #63979 by wasp09
I'll try that this weekend. Thanks.
Busy tried fixing our electric kettle last night. I thought I fixed it but it worked only a few minutes. Have to fix it again.
Channel 11 and 12 work after changing max_aux_channels on CLI. Thanks.
Last edit: 25 Aug 2017 21:33 by wasp09.
19 Oct 2017 19:15 #65134 by BrainHunter
Replied by BrainHunter on topic Issues with DSMX?
Wanderer777 wrote: I encountered some strange issues here with my KingKong 90GT (with DSMX receiver) and my Devo 10 (with 4-in-1 module and Deviation nightly build 2017-04-04):
The quad seems to have 'hiccups'. The motors stop every few seconds in mid-air and the quad does not respond to TX input then for a moment - that's just for the fraction of a second (maybe 0.25 sec). It's very annoying :ohmy:
Distance doesn't matter - it happens right in front of me or 50 meters away.
i had exactly the same problem... Hiccups and no solid light on the rx.
After some research i found out, that the rx of the 90gt is supplied with 5V from the fc. The receiver is made for 3.3V. There is no voltage regulator on the rx. So the rx is used way out of specs.
After inserting a 3.3v ldo in the supply line i got perfect signal and solid led on the rx.
I hope this helps someone out there. Have fun flying
20 Oct 2017 10:45 #65148 by Wanderer777
Replied by Wanderer777 on topic Issues with DSMX?
Switching the receiver wasn't neccessary in my case. I just had to switch from "Spektrum 2048" to "Spektrum 1024" in Betaflight and this solved the issue completely.
The KingKong flies great with the original receiver - at least with a 2S lipo.
Time to create page: 0.111 seconds
