DEVO 12S with RX1202, transmission loss
- Franck
20 May 2017 10:10 #62433
by Franck
DEVO 12S with RX1202, transmission loss was created by Franck
Bonjour à tous, j’ai un problème avec ma radio DEVO 12S et mon RX1202. Elle a 6 mois et je rencontre le même problème qu’avec mon ancienne DEVO 8S. Je l’ai changé car j’ai mis trois avions par terre. Depuis 6 mois que je vol avec ma DEVO 12S, encore un avion par terre après une perte totale de la transmission.
Pouvez-vous m’aider ! Qu’est ce qui fait que j’arrive a un tel résultat…
Google translate
Hello everyone, I have a problem with my radio DEVO 12S and my RX1202. She is 6 months old and I have the same problem as with my old DEVO 8S. I changed it because I put three planes on the ground. For 6 months I have been flying with my DEVO 12S, still a plane on the ground after a total loss of transmission.
Can you help me ! What makes me come to such a result ...
Google translate
20 May 2017 10:26 #62434
Replied by FDR on topic DEVO 12S with RX1202, transmission loss
Do you use fixed ID, or just auto bind?
For example if you had a receiver brownout, it will only reconnect if you used a fixed ID...
- Franck
20 May 2017 11:58 #62436
by Franck
Replied by Franck on topic DEVO 12S with RX1202, transmission loss
Je volais en ID fixe avant le crash. Je n’ai pas volé pendant 2 mois et mon RX1202 ne bindait plus avec ma DEVO12S. J’ai bindé en manuel et ensuite j’ai volé en auto bind. Mais ne peux t’on pas voler en auto bind ? Faut-il vraiment être en ID fixe ?
Google translate
I was flying in fixed ID before the crash. I did not fly for 2 months and my RX1202 no bind with my DEVO12S. I bind into manual and then I flying in auto bind. Can not you fly in auto bind? Do you really need to be in fixed ID?
Google translate
20 May 2017 12:42 #62437
Of course you can fly in auto bind mode, but it is more dangerous, because if the receiver restarts for example because of a voltage drop, it will start in auto bind mode, so you will loose the connection, while if you were using fixed id, it would reconnect...
Time to create page: 0.872 seconds
- DEVO 12S with RX1202, transmission loss
