Deco 8s Sticky Gimbal
- Spyder22
25 May 2017 03:00 #62533
by Spyder22
Deco 8s Sticky Gimbal was created by Spyder22
So today I had the unfortunate experience of dropping my tramsmitter, a Devo 8s running Deviation 5.0.0. Now my elevator stick (but not my aileron stick) gets stuck and is not smooth. I took apart the transmitter and found that the only thing wrong was that the rocker was rubbing on the inside casing for the gimbal (no problems with the spring). Anyone have any fix ideas? I'm considering lubing up the gimbal, if this is a good option, does anyone know how? Also, for some reason after taking apart the transmitter, my switches became a lot more stiff.
It should also be noted that from an electronic standpoint, everything still runs perfectly.
Any ideas are great,y appreciated, Thanks.
- Arakon
25 May 2017 04:05 #62535
by Arakon
Replied by Arakon on topic Deco 8s Sticky Gimbal
Just lubing it up is only gonna mask the issue.. it sounds like something popped out of alignment. I'd start taking the gimbal out and apart and see if something slipped.
- Spyder22
25 May 2017 10:13 #62543
by Spyder22
Replied by Spyder22 on topic Deco 8s Sticky Gimbal
I tried to take the gimbal out of the transmitter, not much luck there, the screws are tighter than I can handle.
- Deco 8s Sticky Gimbal
