Exit USB Mode Devo 12s
- joloebig
26 May 2017 11:20 #62561
by joloebig
Exit USB Mode Devo 12s was created by joloebig
How to exit usb mode on the transmitter devo 12s
if i switch on the transmitter direkt the usb mode/symbol is on the display, no kex helps
The transmitter was stored after the last use. no upgarde or anything
can anyboby help?
Reg
Doro
can anyboby help?
Reg
Doro
26 May 2017 20:10 #62580
Replied by mwm on topic Exit USB Mode Devo 12s
You need to formate the USB disk on your computer, and then copy the files in the distribution to it as per the manual.
- joloebig
26 May 2017 20:39 #62582
by joloebig
Replied by joloebig on topic Exit USB Mode Devo 12s
thx, it works.
but... why the filesystem was corrupt?
thx
Doro
thx
Doro
27 May 2017 05:28 #62589
Not corrupt, just not created. This is normal, and documented in the manual, though it's the last bit in the last paragraph in the relevant section, so easy to overlook.
When the Tx doesn't recognize a file system on the sd memory, it always boots to USB mode so you can format the file system on it. Can't really do much else.
- joloebig
27 May 2017 16:28 #62607
by joloebig
the transmiter was operational, put it only in the box and out off the box the filesystem was corrupt!
no hands on...
but anyhow, it is fixed. hope this will not happend offen.
thx
doro
no hands on...
thx
doro
- tinynja98
17 Sep 2017 18:34 #64463
by tinynja98
Replied by tinynja98 on topic Exit USB Mode Devo 12s
Hey I have the same exact problem as you joloebig. It's really frustrating as it happened to me 3 times since I bought the transmitter, and everytime I power it on, I'm always scared the filesystem will have a problem and I will need to redo the whole thing again. I was of course using the Deviation firmware, and still plan on using it as I just love it.
Does anyone know of any "permanent" fix to this problem? Thanks!
18 Sep 2017 04:06 #64466
Replied by vlad_vy on topic Exit USB Mode Devo 12s
Do you flash library file (at "Library" tab of Dfuse) along with firmware file? For Devo 12 part of the filesystem is placed at library file.
Time to create page: 0.160 seconds
- Exit USB Mode Devo 12s
