Clock settings
- TB34
29 May 2017 20:42 #62682
by TB34
Clock settings was created by TB34
Hi everybody,
I have a little problem with mu DEVO 12S with Deviation TX software.
When I set the clock and date, this is nevermore saved when i swich my TX off.
Can someone explain me why?
Is ther an other permanent battery that died?
Thank you guys for your answers and if there is a tuto to show me what i can do, i' ll really appriciate.
T Benzacar from France
29 May 2017 20:47 #62683
Check the manual for instructions on the replacement...
Replied by FDR on topic Clock settings
Yes, it is in the battery compartment.TB34 wrote: Is ther an other permanent battery that died?
30 May 2017 04:06 #62688
Replied by vlad_vy on topic Clock settings
Remove battery and on the bottom you will see the cover, remove cover and you will see clock battery.
- TB34
30 May 2017 06:49 #62691
by TB34
Replied by TB34 on topic Clock settings
Thank you very much for your answers.
I found it and allready replace the button battery.
T Benzacar
T Benzacar
- TB34
30 May 2017 06:49 #62692
by TB34
Thank you .
I found it.
T Benzacar
I found it.
T Benzacar
Time to create page: 0.050 seconds
- Clock settings
