Clock settings
29 May 2017 20:42 #62682 by TB34
Clock settings was created by TB34
Hi everybody,
I have a little problem with mu DEVO 12S with Deviation TX software.
When I set the clock and date, this is nevermore saved when i swich my TX off.
Can someone explain me why?
Is ther an other permanent battery that died?
Thank you guys for your answers and if there is a tuto to show me what i can do, i' ll really appriciate.:)
T Benzacar from France
29 May 2017 20:47 #62683 by FDR
Replied by FDR on topic Clock settings
TB34 wrote: Is ther an other permanent battery that died?
Yes, it is in the battery compartment.
Check the manual for instructions on the replacement...
30 May 2017 04:06 #62688 by vlad_vy
Replied by vlad_vy on topic Clock settings
Remove battery and on the bottom you will see the cover, remove cover and you will see clock battery.
30 May 2017 06:49 #62691 by TB34
Replied by TB34 on topic Clock settings
Thank you very much for your answers. ;)
I found it and allready replace the button battery.
T Benzacar
30 May 2017 06:49 #62692 by TB34
Thank you .
I found it. ;)
T Benzacar
