Deviation Uploader fails on Windows 10
18 Jul 2017 23:59 #63518 by MikeNH
I'm installing Deviation on my new Devo 7e. I'm up to step "2.4. DFU Installation with Deviation Uploader" when the error occurred.
From the command line execute "java -jar C:\Tmp\BIRDS\DeviationUpload-0.8.0.jar". Result:
Firing Root
Error: Unable to open device
Hotplug detected
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
at deviation.gui.DeviationUploadGUI$2.getValueAt(DeviationUploadGUI.java:180)
at javax.swing.JTable.getValueAt(Unknown Source)
at javax.swing.JTable.prepareRenderer(Unknown Source)
at javax.swing.plaf.basic.BasicTableUI.paintCell(Unknown Source)
at javax.swing.plaf.basic.BasicTableUI.paintCells(Unknown Source)
at javax.swing.plaf.basic.BasicTableUI.paint(Unknown Source)
at javax.swing.plaf.ComponentUI.update(Unknown Source)
at javax.swing.JComponent.paintComponent(Unknown Source)
at javax.swing.JComponent.paint(Unknown Source)
at javax.swing.JComponent.paintChildren(Unknown Source)
at javax.swing.JViewport.paint(Unknown Source)
at javax.swing.JLayeredPane.paint(Unknown Source)
at javax.swing.JComponent.paintToOffscreen(Unknown Source)
at javax.swing.RepaintManager$PaintManager.paintDoubleBuffered(Unknown Source)
at javax.swing.RepaintManager$PaintManager.paint(Unknown Source)
at javax.swing.RepaintManager.paint(Unknown Source)
at java.awt.GraphicsCallback$PaintCallback.run(Unknown Source)
at sun.awt.SunGraphicsCallback.runOneComponent(Unknown Source)
at sun.awt.SunGraphicsCallback.runComponents(Unknown Source)
at java.awt.Container.paint(Unknown Source)
at java.awt.Window.paint(Unknown Source)
at javax.swing.RepaintManager$4.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
at javax.swing.RepaintManager.paintDirtyRegions(Unknown Source)
at javax.swing.RepaintManager.prePaintDirtyRegions(Unknown Source)
at javax.swing.RepaintManager.access$1200(Unknown Source)
at javax.swing.RepaintManager$ProcessingRunnable.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
19 Jul 2017 18:34 #63522 by MikeNH
After posting this problem I did more searching and found that the problem is a documentation issue. I found the following explanation which then made the process clear:
Category: Feedback & Questions
The Deviation manuals suggest 2 methods for installing Deviation:
1. Use the Deviation Java Uploader.
2. Use the Walkera Dfuse installation software.
Method number 2 is for use with computers running the Windows operating system.
Method number 1, the Java Uploader, is cross-platform (Windows, MacOS, Unix, whatever can use Java), and is the simpler, more trouble-free method. The Updater was designed and built by the Deviation development team to ease installation of Deviation on a variety of Devo tramitters.. Using the Java Uploader, you can easily install any version of Deviation from version 4.01 or later, or return to the original Walkera firmware and file system if you wish. Installation uses the Firmware Zip file that you download without needing to unpack it. The Java Uploader takes care of unpacking and putting everything it the appropriate location on the radio. The application also includes other useful features you can explore.
Time to create page: 0.068 seconds
